When I insert the Survey macro inside an Info box macro, when there is a title present for the survey macro the survey seems to sit above the Info macro box and not inside the info macro box.
Also, is there any way to enable to export to CSV and close survey option without having to have a title present? Im not able to get these options working without a title being used.
Im using Confluence 5.1.3 and survey macro version 2.6.0.
Shaun
Hi Shaun,
i can confirm that the title seems to lead to a rendering problem, even when the title is not rendered as a heading (which usually isnt a problem too).
i created a issue as i cant tell you a workaround to get the menubar without having a title: https://github.com/drohne1673/confluence-survey-plugin/issues/34
--Frank
the issue has been resolved. So please try to update to the new version 2.7.0 and see if it fits you
