Transition trigger for Automation for JIRA
Romain VELON
I need to launch a rule on Automation for JIRA when my issue transitionned from "Test" to "Waiting for Fix" and only in that case.
I used:
- Trigger --> Issue transitioned
- Condition --> status = "Test" AND status CHANGED FROM "Test" TO "Waiting For Fix"
There is one case for which it is not working: Let say my issue already transitionned from "Test" to "Waiting for Fix" 10 days ago. Today I transition my issue from "Test" to "Resolved" (this is another status available from Test)
The rule will be launched because my trigger is OK and my condition is OK.
I would like something like "Trigger only from "Test" to "Waiting for Fix""
Thank you for your help.
Romain
3 votes
Nick Menere
September 26, 2017
Hey Romain,
In order to do this you can use the "Compare Condition" and access the changelog for the previous value and current value.
The condition will have following values:
First Value:
{{changelog.status.first.fromString}} - {{changelog.status.first.toString}}
 Condition: Equals
Second value: Test - Waiting for Fix
Hope that is what you were after.
Nick
Romain VELON
Thank you Nick. I used something very similar and it works!
Checks if:
{{#changelog.status}}{{fromString}} - {{toString}}{{/changelog.status}} equals Test - Waiting for Fix
Like Blake Pusztai likes this
Santosh Maurya
I made minor changes and it worked for me..
{{#changelog.status}}{{fromString}} - {{toString}}{{/}}
Equals
Open - In Progress
Anna
March 9, 2022
For some reason it doesn't work for me in Data Center 7.4 version ?
Deleted user June 28, 2019
I found this looking for ways to find the most recent Status, but another way to solve the above use case is to register a Webhook in Jira settings and add it to that transition as a post function.
Sebastián Delmastro
Romain, I have the same rule with several staus from "Test"
Your rule config should be
- Condition --> status = "Waiting For Fix"
With this way it works fine for me. hope it helps.
