Translation does not work
Oliver Santschi May 22, 2014
When I translate to a different language, it saves the content in edit mode, but when i go back in view mode the message is: This page has not yet been translated to English. Did i missed something? See my Screenshots.
P.S.: Is use a evaluation of Scroll Translation: 1.3.2 toghter with a purchased version of Scroll Versions (v.2.4.2) and Confluence 5.4.4
Oliver Santschi May 27, 2014
Problem Solved: I found out that there was a problem with the "Spartez Kwik plugin". When i disabled this, it works.
Deleted user May 25, 2014
Hi Oliver,
Based on your description there is nothing more to do. Did you get a confirmation dialog after you clicked on the save button to decide if the translation is completed or not? Are there any errors in the log file related to Scroll Translations?
For a detailed investigation, can you please create a ticket in our ticket system https://k15t.zendesk.com. In addition to that it would be great if you could attache a full space export together and a support zip to the ticket.
Best regards
Sven
