Sign up Log in
Use JEditor for body field
Angelo Dalli August 22, 2013
I'm testing JETI at the moment and find it very good. The issue is that I'd like to have Jeditor as the renderer for the Body field. Can this be done?
thanks.
Tibor Hegyi _META-INF_
Hi Carl,
I'm afraid it is not possible in a generic way. However, you can use JIRA's wiki markup to format your body content.
Tibor
aarnetadmin
Wooops, just sent off an email regarding this.
Chaining handlers would be great, as using JEditor for (needed) RTF handling precludes the use of JETI, and makes for a difficult choice. Our use case need *both* RTF email handling and JETI features.
Support for JEditor has just been released in version 5.3.3
See documentation for details
I have scheduled this feature. Please follow the corresponding issue.
Ondracek Nikolaus
November 21, 2013
Hi Tibor, this would absolutely improve JETI ! Go for it !
Hi Rob, I have received your email but wanted to answer you here.
To put it short, handler chaining is not possible out-of-the-box due to several reasons.
Neither plugins are prepared for that and classes of a plugin cannot be used in other plugins automatically but only via exported OSGi bundles.
Tibor
Kirill Bobrovskikh
September 3, 2013
Hi Tibor,
JEditor has public javascript api.
For example to convert a textarea to JEditor rendered field you need the following code:
var myTextArea = AJS.$('#my_textarea_id');
JEDITOR.replace(myTextArea, {toolbar : 'JFull'});
Please feel free to contact us if you need any help with integration.
Alex
Hi Alex,
We have started to integrate JEditor and sent our questions to your mail address.
Tibor
