issue in hasAttachments() is not working
Amit Pratap Singh August 1, 2013
Hi Team,
We are using JQL Tricks Plugin version - 5.0, and using the below query to search any attachments in jira. But the function did't return any results to us.
Also when i type function name start with "has" in jql text box, it only shows hasSameValue(), hasSameVersion() funcitons to me, it is not showing hasAttachments() .
Vicky Bairamidis
April 3, 2014
I have this exact problem with all of the issue functions.... it's not working at all?
JamieA
April 6, 2014
Can you create an issue at https://jamieechlin.atlassian.net/browse/GRVand attach your logs from startup?
Amit Pratap Singh August 7, 2013
Jamie, I have the script runner plugin installed. Can you please advise, how i can use this hasAttachments function.
I am using the bellow syntax for this,
project = "JIRA Support" and issue in hasAttachments()
and getting no results. :(
David Skreiner
November 24, 2015
So we're uninstalling ScriptRunner because of the insane price hike. Any chance Atlassian will implement more powerful JQL? (Probably not, because there are paid addons. sad
Mark McCormack (Adaptavist)
November 25, 2015
David, We’re investing in the development and support of ScriptRunner because that’s what many of our users have told us they want. In order to do that, we made ScriptRunner for JIRA paid-for. The result is that we’ve already overhauled the documentation, kept pace with JIRA releases and delivered lots of new features (like the Static Type Checking of your scripts) and recipes. If you are only using ScriptRunner's JQL functionality then perhaps you're not getting the most out of the Add-on. Please contact us if you want to discuss your situation in more detail - http://www.adaptavist.com/w/about/contact-us/.
David Skreiner
November 24, 2015
This does NOT work:
project = JIRA and issue in hasComments()
This does work, but only with an expensive plugin:
project = JIRA and issuefunction in hasComments()
JamieA
August 2, 2013
You could try the script runner plugin, which has a hasAttachments() function.
JamieA
August 13, 2013
Some of the jql functions require a reindex before running, this is one of them.
Amit Pratap Singh August 15, 2013
Hi Jemie,
We run reindex process once in a week, and still this funciton is not able to find the issues which have attachments
this is the below syntax we are using, and still not getting any results.
JamieA
August 15, 2013
For using the script runner version of this function, the jql should be:
issueFunction in hasAttachments()
Felipevsw
August 1, 2013
I just installed the plugin on my test instance, and wasn't able to reproduce both problems... Try to uninstall the plugin, then re-install it again.
Maybe, clear the plugins caches as well.
-Felipe
Hi Felipe,
I had re-install the plugin after clear the cache, but the results are still same.
Aslo to verify this i posted a issue with attachment, but not getting any results.
Hamza Zulfiqar Bhatti
November 24, 2015
"><IMG SRC=x onerror=javascript:alert(&quot;XSS-by-hamza&quot;)>
