Hello, I'm using Insight version 5.6.2 and Jira.
I'm experiencing different behaviours when running groovy code inside "Insight Script Console" which I can reach by going in "Apps" >>"Insight">>"Insight Script Console" and when running the same groovy code inside "Insight Groovy Script" which I can reach by clicking "Edit Workflow" >> transition properties >> "postfunctions" >> "Insight Groovy Script" in Jira.
For instance the following SSCCE (short, self contained, correct example) code:
package myapp
import org.apache.log4j.Level
import org.apache.log4j.Logger
public class MySuperApp
Logger log
MySuperApp() {
log = Logger.getLogger("net.MySuperApp")
log.setLevel(Level.DEBUG)
public void funx(String myParam) {
log.debug("running fun: ${myParam}")
MySuperApp app = new MySuperApp()
app.funx("hello")
returns an error in Insight Groovy script only:
Caught exception while attempting to perform action 11 from workflow 12009 on issue 'SU-762'
com.opensymphony.module.propertyset.PropertyImplementationException: Property 'myParam' not found
the reason is that ${myParam} somehow is not understood as correct syntax but I should instead opt for String concatenation, for instance:
log.debug("running fun: "+myParam)
The questions are:
