Im trying to make a simple post function with scriptrunner groovy.
All I want is to set a value of a field when a list field has a specific value. But it seems like the documented functions doesnt exist.
"issue.setDescription(cfValues['Bug Priority']?.value)" gives
groovy.lang.MissingPropertyException: No such property: cfValues
"def myValue = getFieldById("customfield_10128")" gives cannot find find matching method.
How can I get the value of my list field and use it in a if case to do something...
Try to understand how the code works using CustomField and CustomFieldManager classes. refer this https://community.atlassian.com/t5/Jira-Core-questions/Scriptrunner-post-function-Update-a-custom-text-field-with/qaq-p/267648#M17181
Else plz share your complete code so that I can help you out.
Thanks. i got it to work with this code
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.customfields.manager.OptionsManager
IssueManager issueManager = ComponentAccessor.getIssueManager()
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
CustomField field1 = customFieldManager.getCustomFieldObjects(issue).find {it.name == "Bug Priority"}
def optionsManager = ComponentAccessor.getComponent(OptionsManager)
String field1Value = (String)issue.getCustomFieldValue(field1)
def checkbox = customFieldManager.getCustomFieldObjectByName("Flagged")
def fieldConfig = checkbox.getRelevantConfig(issue)
def option = optionsManager.getOptions(fieldConfig).getOptionForValue("Impediment", null)
if (field1Value == "P1"){
issue.setCustomFieldValue(checkbox, [option])
But I still dont understand why I couldent use cfValues to fetch the field1 value.
What exactly are you trying to write?
def myValue = getFieldById("customfield_10128") is from behaviours
issue.setDescription(cfValues['Bug Priority']?.value) is from worflow functions
Where do you type your code?
Hi
its a post function as the headline says.
If getFieldById only works for behaviours then that explains it.
But why does it complain on cfValues? If I click the little '?' button cfValues is clearly an object that I can use to fetch values of custom fields.
It could be a static compilation error. Just run your code
