On a workflow transition, I run a ScriptRunner script. On a certain condition within this script, I want to transition this issue once again.
This is what I have:
ApplicationUser currentUser = ComponentAccessor.getJiraAuthenticationContext().loggedInUser
IssueService issueService = ComponentAccessor.getIssueService()
def transitionValidationResult = issueService.validateTransition(currentUser, issue.id, transitionId, new IssueInputParametersImpl())
def transitionResult = issueService.transition(currentUser, transitionValidationResult)
I get no error.
And when I have a look into my issue, I see in the Issue History an entry which says the transition happened - but actually the issue is still in the "old" status.
I run this on a Service Desk project.
Hi @Steffen Becker ,
That is the code I am using to transition issues :
import com.atlassian.jira.workflow.WorkflowTransitionUtil
import com.atlassian.jira.util.JiraUtils
WorkflowTransitionUtil workflowTransitionUtil = ( WorkflowTransitionUtil ) JiraUtils.loadComponent( WorkflowTransitionUtilImpl.class );
workflowTransitionUtil.setIssue(issue);
workflowTransitionUtil.setUserkey("user_key")
def transitionId = 11
workflowTransitionUtil.setAction(transitionId);
workflowTransitionUtil.progress();
Maybe that will help.
Thank you it works!
Even though it prints me a warning message: "use ComponentManager.loadComponent"
Maybe this snippet is a bit outdated, but I cannot find the loadComponent method in the javadoc, and jiraUtils' one is not deprecated in the javadoc. Maybe something to keep in mind for future versions though.
If you are satisfied with the answer please mark it as accepted so it can help others too.
Hello @Antoine Berry
I try to do the same thing, a post function that clones the issue (Scriptrunner PF) and that will transition the cloned issue, but this snippet does not work for me.
Any idea please ?
java.lang.NullPointerException: Cannot get property 'class' on null object
at Script306.run(Script306.groovy:11)
line 11 is :
WorkflowTransitionUtil workflowTransitionUtil = ( WorkflowTransitionUtil ) JiraUtils.loadComponent(WorkflowTransitionUtilImpl.class);
I found another snippet here : https://community.atlassian.com/t5/Jira-questions/How-to-transition-an-issue-from-a-groovy-script-in-JIRA/qaq-p/917751
I adapted to my environment :
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.bc.issue.IssueService;
import com.atlassian.jira.issue.IssueInputParametersImpl;
import org.apache.log4j.Logger;
import org.apache.log4j.Level;
import com.atlassian.jira.event.issue.IssueEventBundle;
import com.atlassian.jira.event.issue.IssueEventManager;
import com.atlassian.jira.event.issue.IssueEventBundleFactory;
import com.atlassian.jira.event.issue.IssueEvent;
import com.opensymphony.workflow.WorkflowContext
import com.atlassian.jira.workflow.WorkflowTransitionUtil;
import com.atlassian.jira.workflow.WorkflowTransitionUtilImpl;
import com.atlassian.jira.util.JiraUtils;
import com.opensymphony.workflow.loader.StepDescriptor;
import com.atlassian.jira.*;
import com.atlassian.jira.workflow.WorkflowManager;
import com.atlassian.jira.workflow.JiraWorkflow;
import com.opensymphony.workflow.loader.ActionDescriptor;
def customFieldManagerT = ComponentAccessor.getCustomFieldManager();
def issueEventManager = ComponentAccessor.getIssueEventManager();
int EVENT_ID = 711
def issueManager = ComponentAccessor.getIssueManager()
MutableIssue mi = issueManager.getIssueObject(issue.getKey());
workflowTransitionUtil.setIssue(mi);
workflowTransitionUtil.setAction(EVENT_ID);
//workflowTransitionUtil.validate(); i had to comment out these 2 last lines because I had errors and the clone was not created
//workflowTransitionUtil.progress();
Even if this time, the post function is executed without errors and does create the clone for the 1st time, the transition of the cloned issue did not change ...
Any idea ?
Hi @oneagain ,
I have found a snippet, I think it is worth a try :
import com.atlassian.jira.workflow.WorkflowTransitionUtilFactory
WorkflowTransitionUtil workflowTransitionUtil = ComponentAccessor.getComponent(WorkflowTransitionUtilFactory.class).create()
Thank you but just tested in the postfunction : ko
java.lang.IllegalArgumentException: User null doesn't have permission transition for issue null. at com.atlassian.jira.workflow.WorkflowTransitionUtilImpl.retrieveActionDescriptorWithPermissionCheck(WorkflowTransitionUtilImpl.java:142) at com.atlassian.jira.workflow.WorkflowTransitionUtilImpl.getActionDescriptor(WorkflowTransitionUtilImpl.java:133) at com.atlassian.jira.workflow.WorkflowTransitionUtilImpl.hasScreen(WorkflowTransitionUtilImpl.java:361) at com.atlassian.jira.workflow.WorkflowTransitionUtilImpl.progress(WorkflowTransitionUtilImpl.java:338) at com.atlassian.jira.workflow.WorkflowTransitionUtil$progress$2.call(Unknown Source) at Script153.run(Script153.groovy:11)
Fyi, the post function is the "Clones an issue, and links [ScriptRunner]" and in the additional action I added a small snippet to empty a specific field, which works, but not the part that should transition the newly cloned/created issue.
Based on this last error, it seems it is not able to transition a null issue, so it does not exist at this time. But how is he able to empty the field I asked ?
I also tried this script from adaptavist : https://library.adaptavist.com/entity/transition-an-issue-using-issue-input-parameters
And it is dedicated for post function so I thought it would work.
So I removed the non necessary part to go like this :
final actionName = 'Done'
def issueService = ComponentAccessor.issueService
def workflowManager = ComponentAccessor.workflowManager
def workflowActionId = workflowManager.getWorkflow(issue).allActions.findByName(actionName)?.id
def issueInputParameters = issueService.newIssueInputParameters()
def transitionValidationResult = issueService.validateTransition(currentUser, issue.id, workflowActionId, issueInputParameters)
assert transitionValidationResult.valid: transitionValidationResult.errorCollection
assert transitionResult.valid: transitionResult.errorCollection
But it failed, also with error like "null issue" :
java.lang.AssertionError: Errors: {}
Error Messages: [You can not transition a null issue.]. Expression: transitionValidationResult.valid
at Script189.run(Script189.groovy:19)
at com.onresolve.scriptrunner.runner.AbstractScriptRunner.runScriptAndGetContext(AbstractScriptRunner.groovy:174)
at com.onresolve.scriptrunner.runner.AbstractScriptRunner$runScriptAndGetContext$3.callCurrent(Unknown Source)
at com.onresolve.scriptrunner.runner.AbstractScriptRunner.runScriptAndGetContext(AbstractScriptRunner.groovy:293)
at com.onresolve.scriptrunner.runner.ScriptRunner$runScriptAndGetContext$9.call(Unknown Source)
at com.onresolve.scriptrunner.canned.jira.utils.ConditionUtils.doAdditional(ConditionUtils.groovy:112)
at com.onresolve.scriptrunner.canned.jira.utils.ConditionUtils$doAdditional.call(Unknown Source)
at com.onresolve.scriptrunner.workflow.DefaultWorkflowScriptExecutor.doAdditional(DefaultWorkflowScriptExecutor.groovy:29)
at com.onresolve.scriptrunner.workflow.WorkflowScriptExecutor$doAdditional$0.call(Unknown Source)
at com.onresolve.scriptrunner.canned.jira.utils.AbstractCloneIssue.cloneIssue(AbstractCloneIssue.groovy:270)
at com.onresolve.scriptrunner.canned.jira.utils.AbstractCloneIssue.execute(AbstractCloneIssue.groovy:184)
at com.onresolve.scriptrunner.canned.jira.utils.CopyIssueWithAttachments.super$4$execute(CopyIssueWithAttachments.groovy)
at com.onresolve.scriptrunner.canned.jira.utils.CopyIssueWithAttachments.execute(CopyIssueWithAttachments.groovy:29)
at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.CloneIssue.super$5$execute(CloneIssue.groovy)
at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.CloneIssue.execute(CloneIssue.groovy:158)
at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.CloneIssue$execute$0.callCurrent(Unknown Source)
at com.onresolve.scriptrunner.canned.jira.workflow.AbstractWorkflowCannedScript.execute(AbstractWorkflowCannedScript.groovy:23)
at com.onresolve.scriptrunner.canned.jira.workflow.AbstractWorkflowCannedScript$execute$2.call(Unknown Source)
at com.onresolve.scriptrunner.jira.workflow.AbstractScriptWorkflowFunction$_run_closure2.doCall(AbstractScriptWorkflowFunction.groovy:89)
at com.onresolve.scriptrunner.jira.workflow.AbstractScriptWorkflowFunction$_run_closure2.doCall(AbstractScriptWorkflowFunction.groovy)
at com.onresolve.scriptrunner.runner.diag.DiagnosticsManagerImpl$DiagnosticsExecutionHandlerImpl$_execute_closure1.doCall(DiagnosticsManagerImpl.groovy:359)
at com.onresolve.scriptrunner.runner.diag.DiagnosticsManagerImpl$DiagnosticsExecutionHandlerImpl$_execute_closure1.doCall(DiagnosticsManagerImpl.groovy)
at com.onresolve.scriptrunner.runner.ScriptExecutionRecorder.withRecording(ScriptExecutionRecorder.groovy:13)
at com.onresolve.scriptrunner.runner.ScriptExecutionRecorder$withRecording.call(Unknown Source)
at com.onresolve.scriptrunner.runner.diag.DiagnosticsManagerImpl$DiagnosticsExecutionHandlerImpl.execute(DiagnosticsManagerImpl.groovy:357)
at com.onresolve.scriptrunner.runner.diag.DiagnosticsExecutionHandler$execute$2.call(Unknown Source)
at com.onresolve.scriptrunner.jira.workflow.AbstractScriptWorkflowFunction.run(AbstractScriptWorkflowFunction.groovy:82)
Hello, just to complete this thread, I finally ended with this :
(I was actually missing the part doAfterCreate = {} with the help of Adaptavist)
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.user.ApplicationUser
doAfterCreate = { // the step you want sub-tasks to be transitioned tofinal actionName = 'Done' def issueService = ComponentAccessor.issueService def workflowManager = ComponentAccessor.workflowManagerdef workflowActionId = workflowManager.getWorkflow(issue).allActions.findByName(actionName)?.id def issueInputParameters = issueService.newIssueInputParameters() def transitionValidationResult = issueService.validateTransition(currentUser, issue.id, workflowActionId, issueInputParameters) assert transitionValidationResult.valid: transitionValidationResult.errorCollection def transitionResult = issueService.transition(currentUser, transitionValidationResult) assert transitionResult.valid: transitionResult.errorCollection }
Tried this also, it works from the SR console, for 1 existing issue (already created)
but not in a post function to be applied on the soon-to-be cloned issue ... :(
import com.atlassian.sal.api.user.UserManager
import com.atlassian.jira.user.util.UserManager
import com.atlassian.jira.bc.issue.IssueService.TransitionValidationResult;
//final transitionId = 761
final id = 21
def issueId= "TEST-15"
//Issue issue = getIssueByID(issueId)
def issue = issueManager.getIssueObject(issueId)
def boolean transitionIssue(Issue issue, int Id) {
boolean result = false;
IssueService issueService = ComponentAccessor.getIssueService();
IssueService.IssueResult transResult;
UserManager userManager = ComponentAccessor.getUserManager()
ApplicationUser user = userManager.getUserByName("valiantys")
TransitionValidationResult validationResult = issueService.validateTransition(user, issue.getId(), Id, issueService.newIssueInputParameters());
if (validationResult.isValid()) {
transResult = issueService.transition(user, validationResult);
log.warn("Transition has been made")
} else {
log.error("There was an issue with this transition : " + validationResult.getErrorCollection())
transitionIssue(issue,id)
Hi!
The accepted answer was useful and we used it a lot. However the class WorkflowTransitionUtil became deprecated in Jira 9.x and Scriptrunner 8.x. The workaround suggested by the official documentation suggests using IssueService.transition() which reintroduces the old problem suggested in the original post. At least for us in the case of transitioning an issue in the post function. For us, also, there is no error, the log says the transition was completed successfully, but the issue remains in the old status.
Is there an answer for this problem without using WorkflowTransitionUtil?
Marina
I would be interested in this as well. Same problem here and since WorkflowTransitionUtil is deprecated, there is no visible solution to us.
Thanks for any help!
Stefan
