Hi everyone,
As you explore the new navigation, we're interested in learning about your usage patterns and preferences to enhance your experience. Since this is an experimental phase, we're rolling out a limited set of features, and there may be bugs or unintended behavior. Here are more details about these bugs or issues.
Question | Response/Answer |
Where can I find Project settings? | We’ve disabled Project settings for this experiment. Disable the Chrome extension to access Project settings for your project. You can toggle the extension on/off at your convenience. |
Why can’t I create a project using the icon next to Projects?
Selecting the While the sidebar shows you a limited number of projects, this dedicated page lets you explore the list of existing projects and then create a new project. |
Why can’t I resize the side navigation?
We’re working on fixing the side navigation and it might not work too well for you. Instead, we recommend that you use the Expand/Collapse button ( |
Does the extension work on any other browsers like Brave? |
The extension is available to use in Chrome browsers only, and we don’t support other browsers. If you’ve found a way to make it work, we’d love to know more. So please share your experience with us. |
Will the Chrome extension alter the use of Jira and its UI? |
The extension will alter the Jira UI to show the same navigation options but in a different way. |
Why can I still see the current navigation before the new navigation loads, especially when navigating to new pages? |
This is a known bug and is expected. Please wait a bit for the new navigation to load.
Can I see single and multiple pages for App menus in the new navigation via the Chrome extension? |
The new navigation via Chrome extension doesn't support the display of the menu items for Apps. |
Will the Chrome extension interact with the Jira instance via API? |
The extension has to make API calls but will not change the state of the Jira page. |
Why can't I access Calendars and Plans? |
Not all menu items under Plans might be available in the extension for experiment. Also, newly created Plans aren't available in Recents. You can access newly created Plans by selecting View all plans. |
Why aren’t my custom colors for navigation displaying correctly on the Jira instance? |
For this experiment, we only support the default color scheme in Jira. We’re still exploring custom colors for navigation. You can reach out to your Jira admin to change the color scheme of your instance. If you’re an admin, you can go to Settings > System > Look and feel > Navigation colors and select Revert. |
Why can't I access the top navigation when I select some tabs in a project? |
The top navigation disappears when you select the below tabs in a project:
This is unintended behavior and a known issue. |
Why does the top navigation move to the bottom when I select the Security tab in my project?
In the Chrome extension, the top navigation moves to the bottom of the page when you select the Security tab in your project. This is a known issue with the Chrome extension. Note: To see the security feature for your project in Jira, you'll have to enable it first. Learn about the Security feature. |
For Jira Service Management |
Why can’t I see the number of issues for queues in the sidebar?
We’re still exploring this functionality, and you won’t be able to see the number of issues for queues in Jira Service Management projects. If this is important for your work, we’d love to hear more. In the meantime, You can toggle the extension on/off at your convenience.
Why can’t I find Channels in my Jira Service Management project?
We’re still exploring this functionality, and you won’t be able to see Channels in the sidebar for Jira Service Management projects. If this is important for your work, we’d love to hear more. In the meantime, You can toggle the extension on/off at your convenience.
For Jira Product Discovery |
Why isn’t the Chrome extension working for Jira Product Discovery? |
We haven’t yet implemented the new navigation for Jira Product Discovery, and you won’t be able to use the extension for it. Toggle the extension off if you’re using Jira Product Discovery projects. You can always toggle the extension on for other projects in Jira Software, Jira Work Management, and Jira Service Management. |
We’ll keep adding more to the list of identified issues/bugs, so please watch this page.
If something isn’t working out for you, you can revert to the old experience by toggling off the extension. Once you've completed your task, you can toggle it back on to return to the new navigation.
We’d love to hear about your experience using the new navigation in Jira. Share with us:
Any tasks you found challenging to complete using the new navigation
How you've personalized your sidebar to suit your work
What’s working well for you
What’s not working well for you
Any other comments or suggestions, no matter how minor
Happy experimenting,
The Jira Navigation team
Varsha Patel
6 comments
