×Hi All,
I have created the sprint with start & end dates as 1st Jul and 29th Jul and have added all the tasks and bugs into the sprint.
When I try to access the insights I can't see the sprint burndown chart
As per the support article, I have enabled estimates and added story points, story point estimates, original estimates, and time tracking and using all the fields for all the issues types in jira.
Please let me know what I'm missing here..?
Thanks in Advance.
Hi Huy Quang,
Thanks for your reply.
I have followed the steps you have suggested and when I click "Configure" from the board I'm not seeing the "Estimation Tab".
rather I can see the "Estimation" from the features tab of my jira like the snap below
I have already selected the story point here which really didn't bring up the sprint burndown chart.
I have changed the "estimation " to track using time but had no luck still the sprint burndown is not showing in the insights.
I see. I'm using the step for Jira Server, however I think I have same problem with you when the first using Jira Cloud. The burnchart for story point still work but for the time estimate doesn't. So I change the type of project when I created the new one
Please ensure with me that when you create your project. You selected the "Company-managed" instead of "Team-managed".
And try to setting all the things like I said before, I logged work on an issue and the burndown chart is finally worked. I don't know why but maybe you can try this way.
This can happen if the dates we're off when you set the Sprint. Sometimes JIRA will mess them up and sometimes it's user error (psst.. it's mostly JIRA).
Check the Start and Stop dates under edit sprint on the backlog view.
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Get the most out of Jira
Explore the interface and basic Jira terms, then discover how to effectively manage your work.
Learning Path
Atlassian tools and practices for developers
Focus on your development work by using Jira software features and functions efficiently.
Atlassian Certified Associate
Jira Software Essentials certification
Demonstrate proficiency in utilizing essential Jira features and working efficiently with Agile frameworks like Kanban and Scrum.
