Introducing Postmortems for Opsgenie
When incidents happen, it is crucial to diagnose and solve the problem as fast as possible. Equally important to this, teams need a way to reflect on why the incident occurred and how they can improve their response in the future, i.e., they need to learn from their mistakes. Postmortem reports play a huge part in this process.
As a part of our Incident Management feature set, we are excited to introduce postmortems for Opsgenie!
Understand what led to the incident and how it is resolved
When an incident is resolved, postmortems can also take up a lot of time to prepare - even more than resolving the problem. Opsgenie allows you to easily create postmortems by loading a template prefilled with your incident data.
The template includes the sections that you can capture the key points of the incident, such as incident's impact, actions taken to mitigate or resolve the incident, and the root cause. These sections can be modified according to your needs.
Postmortems in Opsgenie also leverage Incident Timelines and the timeline of your incident is automatically included in the report for you to review and make necessary edits before publishing.
Make sure your follow-up tasks are listed and prioritized
Peacetime is a great opportunity to improve your infrastructure and response processes since your main priority will be dealing with the incident during wartime. Doing a thorough postmortem after the incident resolution will help you clarify what you should work on during peacetime to mitigate occurrences of the incidents.
You can easily link Jira issues right from your postmortem report and navigate to the issue details in Jira by simply clicking on the issue. This allows you to make sure that the follow-up tasks are communicated with the related stakeholders and your teams are aware of the prioritized tasks and what should they work on in the given timeframe.
If you are creating postmortems manually or struggling to share relevant incident details with your stakeholders, give Opsgenie a try and see how to:
  • Save time and effort compiling incident postmortems
  • Ensure that all of the relevant incident history is captured in your reports
  • Share your learnings and next steps with your team and stakeholders
Try it out and and let us know what you think!
13 comments
Peter Leclercq September 26, 2019
How can one share the postmortem with OG "stakeholders" or external people (not users of OG)? There is no download/export button and the browser print function will not allow you to show all information (such as timeline and details - incident duration) on the document.
Like • Anthony Moreno likes this
Kate Clavet
November 6, 2019
Hi there Peter,
We've recently introduced a new feature for Postmortems that allow you to export them to Confluence. Here's more information: https://www.atlassian.com/blog/opsgenie/shareable-postmortems-in-opsgenie
Peter Leclercq November 7, 2019
Hi @Kate Clavet Thanks for pointing out the new feature. Unfortunately it doesn't work with me. I tried exporting existing postmortems and I still only have the delete button. Does it only work with newly created ones? Sound a bit limiting, but perhaps I am doing something wrong. (I did install the Confluence timeline app).
Kate Clavet
November 7, 2019
Hi @Peter Leclercq did you purchase your Opsgenie account from Opsgenie.com? or via the Jira Admin panel?
Kate
@Kate Clavet Directly via Opsgenie.com back in the days of the Jira Ops trial.
Kate Clavet
November 7, 2019
@Peter Leclercq Yes so in this case, exporting is available to folks who have purchased via the Jira Admin panel. We are working to roll this out to all Opsgenie accounts in the future.
Thiago_Carvalho_Galvão
April 17, 2020
How do I link or post-mortem my status done from jira?
Dorian Peake
October 7, 2020
@Kate ClavetI purchased Opsgenie as part of my atlassian suite a few weeks ago and I'm unable to export to Confluence. There is an export to confluence option, but the dropdown menu for spaces has no entries.
Kate Clavet
October 7, 2020
HI @Dorian Peake when you start to type a letter, so spaces populate? Let me know how this goes!
Martin Wallgren
November 4, 2020
We are considering setting up Opsgenie for our incident management, but I can't find any information about exporting postmortems to self hosted confluence instances.
Is it possible to export postmortems to self hosted confluence sites (via Opsgenie Edge Connector)?
Kate Clavet
November 9, 2020
@Martin Wallgren , hi there and thanks for your question.
This is currently only available for those using Confluence Cloud and Opsgenie, it's not currently available for self-hosted Confluence.
Best,
Kate
Like • Martin Wallgren likes this
fabien-ruffin February 9, 2021
@Kate Clavet I had the same issue as Dorian Peake above and your suggestion did work for me.
Feature request: I have to say that this UX is extremely confusing. I spent quite some time checking my integrations, to try to figure out why my spaces were not showing in the list. An easy fix would be to say "Start typing to get suggestions" instead of "No options" in that drop-down list.
Like • Gautam Vij likes this
Kate Clavet
February 9, 2021
@fabien-ruffin Thanks for the feedback. You raise some really helpful points, I'll pass this along to the team.
Best,
Kate
