Hi everyone.
I'm new to using API's. When I'm trying to add note to Alert via IPA I'm getting the error:
403 ERROR
The request could not be satisfied.
This distribution is not configured to allow the HTTP request method that was used for this request. The distribution supports only cachable requests.
We can't connect to the server for this app or website at this time. There might be too much traffic or a configuration error. Try again later, or contact the app or website owner.
If you provide content to customers through CloudFront, you can find steps to troubleshoot and help prevent this error by reviewing the CloudFront documentation.
Generated by cloudfront (CloudFront)
Request ID: IZRkiFS1DofLrBqVJENTXDABYBjiMA4FCoq19s6ag6QMV29Rv-i6iQ==
What I'm doing wrong?
Example from documentation:
curl -X POST https://api.opsgenie.com/v2/alerts/8418d193-2dab-4490-b331-8c02cdd196b7/notes?identifierType=id
-H "Authorization: GenieKey eb243592-faa2-4ba2-a551q-1afdf565c889"
-H "Content-Type: application/json"
-d
"user":"Monitoring Script",
"source":"AWS Lambda",
"note":"Action executed via Alert API"
My request:
curl -X POST https://mycompany.app.eu.opsgenie.com/v2/alerts/4d704a13-3ca3-4c57-a8ca-c8ab21211b5a-1594821021926/notes?identifierType=id
-H "Authorization: GenieKey xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"
-d
"user":"DB Manager",
"source":"Test",
"note":"Test Note"
Documentation:
https://docs.opsgenie.com/docs/alert-api
Please help.
Michael
Ok, My bad. I need to use https://api.eu.opsgenie.com instead of https://mycompany.app.eu.opsgenie.com. It wasn't obvious to me. I thought https://api.eu.opsgenie.com is an example.
