How to send notification when alert deduplication kicks in?
Lukasz Kaminski May 14, 2020
I was not able to find solution here.
How can I set up notifications to all in escalation policy each time the alert deduplication count is increased?
Lukasz
Nick Haller
May 15, 2020
Hi @Lukasz Kaminski ,
"Alert de-duplication is one of the key features that Opsgenie provides to help reducing the number of alerts and to prevent alert fatigue. Because monitoring systems can be quite 'chatty' by sending many events for the same problem and having to manage many alerts that were raised for the same or relevant source, de-duplication becomes crucial for many cases" - https://docs.opsgenie.com/docs/alert-deduplication
So to have notifications send each time an alert deduplicates would essentially go against this core practice. It is not currently possible to adjust this either; have deduplication notify each time the alert increases in count.
The only work around would be having a new alert created vs. deduplicating the alert. Since deduplication is dependent on the alias field of the alert, you'd need to adjust what data parses in the alias field - which can be done on the integration level under the advanced tab.
Please let us know if you have any other questions around this or in general.
Best,
Nick
Lukasz Kaminski May 25, 2020
It answers my question, thanks a lot.
