Integrating OpsGenie with WhatsUpGold - Resolved
Alex Gorham
Hello!
Has anyone been able to successfully integrate WUG with OpsGenie to create alerts? I've created the integration in OpsGenie, created the Action and Alert and policy in WUG, however no alerts are flowing. Any advice would be greatly appreciated!
Howard Nedd
Have you checked the conditions? Do you have a printscreen of your configuration on Opsgenie side?
Howard
Alex Gorham
@Howard Nedd Thanks for your response - Are you referring to a screenshot the integration itself?
Howard Nedd
Yes
Alex Gorham
I've blocked out the api key for security purposes, but the integration itself is very basic. One team is assigned, and the action and alert and action policy are created in WUG.
Howard Nedd
This is just your integration setup but have you set specific conditions below? That is what I ment.
Regards
Howard
Alex Gorham
Hey @Howard Nedd - I've actually got this figured out! It was a configuration issue on the WUG side. Thanks for your help though.
Howard Nedd
Perfect!
