Is there a way to customize the payload of the webhook integration
Dewey Du
May 5, 2022
I'd like to send notifications to wecom using webhook while alerts are created or updated. However, the JSON payload received by wecom robot should be in a format like the below. So if there is a way to customize the alert payload send by opsgenie?
And also does opsgenie support custom integration written by community. I didn't find any doc, or else I'd like to create an customized integration and convert the payload by myself
    "msgtype": "text",
    "text": {"content":"xxx"}
John M
May 6, 2022 edited
Hi @Dewey Du,
There is no feature that allows you to customize the webhook payload, so you would need to send it to another endpoint first and modify it before sending it to Wecom. I didn't see any community project for this either, so you would most likely need to build that integration yourself.
Dewey Du
May 6, 2022
Got it, thanks.
