JSM Incident integration to Opsgenie
Okan Zengin January 15, 2024 edited
Incidents that created on JSM is not showing on Opsgenie Incidents. How can i integrate the JSM incidents to Opsgenie for creating a postmortem report?
Animesh Singh
January 17, 2024
Hello Okan Zengin,
Greetings! I hope you are doing great!
Thanks for reaching out to Atlassian Community. In the current build using JSM/JSM cloud integration an incident created on JSM can only create an alert on Opsgenie. In order to create an incident from the alert created, you will need to create incident rules which would match the alerts created on Opsgenie by the incident on JSM and will then create an incident on Opsgenie.
We do have an open feature request for the use-case you are looking into. I would recommend you to vote/comment on the feature request. You can use the following link for tracking the same,
https://jira.atlassian.com/browse/OPSGENIE-1274
I hope this helps and I wish you an amazing day ahead!
Best Regards,
Animesh
Cloud Support Engineer
Okan Zengin January 17, 2024
Thanks a lot @Animesh Singh
