Opsgenie Maintenance API
Roshna March 24, 2024
Hi Team,
I am trying to schedule a maintenance for a given notification policy using API but it keeps failing
List of available notification policies:
curl -X GET 'https://api.opsgenie.com/v2/policies/notification?teamId=e56dce09-300d-476d-abbd-1a68a379df91' --header 'Authorization: GenieKey <removed >
{"data":[{"id":"abdf75c6-8be8-434e-849a-bcd39b2bc251","name":"Sites down simultaneously","type":"notification","order":0,"enabled":true},{"id":"b0809a2d-f661-42d8-8449-5d3607a23e1c","name":"OPS-62832","type":"notification","order":1,"enabled":false}],"took":0.032,"requestId":"673861ab-87c0-45f6-b743-ee4a9975673b"}
Creating maintenance policy for "b0809a2d-f661-42d8-8449-5d3607a23e1c"
curl -X POST 'https://api.opsgenie.com/v1/maintenance?teamId=e56dce09-300d-476d-abbd-1a68a379df91' --header 'Authorization: GenieKey <removed>' --header 'Content-Type: application/json' --data '{"description": "OPS-62832", "time": {"type": "schedule", "startDate": "2024-03-22T00:00:00.000+1000", "endDate": "2024-03-22T06:00:00.000+1000"}, "rules": [{"state": "enabled", "entity": {"id": "b0809a2d-f661-42d8-8449-5d3607a23e1c", "type": "policy"}}]}'
{"message":"Policy with given id [b0809a2d-f661-42d8-8449-5d3607a23e1c] can not be found","took":0.05,"requestId":"b7dafb9c-290a-4813-96d2-dce87327de56"}(py3-env)
I'm uncertain whether I'm overlooking something or not approaching this correctly.
Could someone kindly assist me with this issue?
Roshna March 25, 2024
Issue resolved after setting correct permission for the key.
