Opsgenie and Zabbix
Louis_DaCosta April 11, 2023
Is it possible to integrate Opsgenie Cloud with Zabbix in on-prem version ?
Nick Haller
April 11, 2023 edited
Hi @Louis_DaCosta ,
If you are asking if Opsgenie can communicate with Zabbix / send Opsgenie alert actions back to the Zabbix alert - then yes - that should be possible.
Opsgenie has an OEC plugin which would most likely be needed. OEC is a lightweight app used to communicate with external systems that are not accessible from the public internet.
Thank you for your answer !
Like • Nick Haller likes this
Andrew Laden
April 14, 2023
Absolutely. It works great.
There are two variants on how to do it however. The original way is documented
https://blog.zabbix.com/scheduling-and-escalation-made-easy-zabbix-and-opsgenie-integration/10005/
Later on Zabbix added a "native" integration.
https://www.zabbix.com/integrations/opsgenie
I prefer the earlier method as I was able to do a little more customization. But the Native one is probably a little easier to set up.
Louis_DaCosta April 16, 2023
