Activity simulation method?
Carmen Odimba
I decided to test Beacon with a One Atlassian instance before trying it out on our company service desk. Which method would you advise in order to simulate activity on Confluence etc.?
2 accepted
3 votes
Andy Gladstone
@Carmen Odimba I would do the following:
  1. To simulate page crawling
    1. Rapid searches for pages with very specific terms
    2. Opening 20-30 pages in a short period
  2. Installing apps from the marketplace
  3. Create API Keys
  4. Create a new user and set them as admin (use a second email address you may have)
I hope this helps!
Carmen Odimba
July 11, 2023 edited
Hi @Andy Gladstone ,
thank you so much. I'll try these out and will give some feedback.
Like • Andy Gladstone likes this
Carmen Odimba
I had good results with number 2, 3 and 4.
Thank you very much!
Jeremy Galloway
August 7, 2023
Some additional options to generate activity to create alerts would be to:
Add a new user to Beacon
Create an IP Allowlist (no need to enable it)
Create an Application Tunnel (no need to enable it)
Have an admin create a new API key
Export the Admin Audit log
Carmen Odimba
Hi Jeremy,
I got results by adding a new user to Beacon as well as creating new API keys. I'll test the other options you mentioned as well, thank you very much.
