Can we verify domain without using Guard
Alex Kiselev _Itransition_
November 6, 2024
Hi community,
Could you help me with domain verify process.
Is that correct that I can verify domain without adding Guard subscription?
https://support.atlassian.com/user-management/docs/verify-a-domain-to-manage-accounts/
So it looks like I will be able only "edit, delete, or deactivate " managed accounts.
But any security features (SSO, user provisioning, enforced MFA) won't be available.
Could somebody confirm please?
And regards to the MFA - in case of domain verified - do user have possibility to use 'personal' MFA (not enforced one)?
https://support.atlassian.com/atlassian-account/docs/manage-two-step-verification-for-your-atlassian-account/
Thank you.
Best regards,
Alex.
November 6, 2024
Hi @Aaron Pavez [ServiceRocket]
Thank you for help!
But my question is "can we verify domain and what the capabilities provided without Atlassian Guard".
Can you help me?
Thank you.
Best regards,
Alex.
Hi!
Yes, you can. Guard isnt needed for that.
About MFA
https://support.atlassian.com/security-and-access-policies/docs/enforce-two-step-verification/
Any user can enable two-step verification for their Atlassian account at no cost. However, as an organization admin, if you'd like to require all your users to enable two-step verification, you'll need an Atlassian Guard Standard subscription
You can see all that with a standard license under admin.atlassian.com
All that is mentioned here. What guard does. Everything else can be found under admin.atlassian.com for you to check.
https://support.atlassian.com/security-and-access-policies/docs/atlassian-guard-product-and-plan-availability/
Regards
Like • 2 people like this
