How to have Rovo agent use dependent library which is not in a public repository?
Galina Rogozinsky
August 20, 2025
Hi
I need my code to use another library which is a part of my company's repository and available in Bitbucket. I asked Rovo agent to add the needed dependency in pom.xml which it did and updated code to use this dependent class, but the generated code had compilation errors which I assume due to a fact that my library is not a part of a public repository. Is there a way to solve this?
Thank you.
2 comments
Jaime Escribano _knowmad mood_
Hi @Galina Rogozinsky
Welcome to the community!
My first suggestion would be to create a Rovo agent that includes a URL to the repository as part of its instructions.
Another suggestion, whenever Rovo makes a mistake, write back to it telling him what the mistake was and why it failed, even copying and pasting the compilation error. This usually helps get better responses.
Lastly, ask it to test the code itself!
With that being said, I don't know if we'll ever see a world where LLM's will give us code without compilation errors :D Hallucinations are a nasty thing
Like Jovana Dunisijevic likes this
Jovana Dunisijevic
August 24, 2025
Hey @Galina Rogozinsky !
When you add a dependency in pom.xml that points to a library only available in your company's private Bitbucket repository. Maven can't fetch it unless that library has been published to a Maven repository that your project can access.
By default, Maven looks in public repositories (like Maven Central), so if your internal library isn't published to a private Maven repository (like JFrog Artifactory or Nexus), the dependency won't resolve, leading to compilation errors.
Try this!
1) Publish the Internal Library to a Private Maven Repository
  • Your company should publish the internal library (from Bitbucket) to a private Maven repository (e.g., JFrog Artifactory, Nexus, or a company-hosted Maven repo).
  • Once published, add the repository details to your project's pom.xml under the <repositories> section, so Maven knows where to look for the dependency.
2) Configure Your Project to Use the Private Repository
  • In your pom.xml, add the repository configuration:
    <repositories> <repository> <id>company-internal</id> <url>https://your-artifactory-url/repository/maven-releases/</url> </repository> </repositories>
  • Make sure your dependency declaration matches the groupId, artifactId, and version used when publishing the library.
Alternatively, you can build the Internal library locally (as a temporary workaround)
  • If publishing to a Maven repo isn't possible yet, you can build the internal library locally and install it to your local Maven repository using:
    mvn install
    This makes the library available for your project on your machine only.
@Jaime Escribano _knowmad mood_ also shared a good tip!
Let us know if this helps you in any way!
Kindest regards,
Jov
