[PYI-34566:ERROR] Failed to load Python shared library
tom td
October 14, 2025
I was trying to install rovodev
https://support.atlassian.com/rovo/docs/install-and-run-rovo-dev-cli-on-your-device/
All previous steps are successful.
acli rovodev auth login
Authentication successful
acli rovodev run
[PYI-34566:ERROR] Failed to load Python shared library '/Users/tuchang/.local/share/acli/1.3.4-stable/plugin/rovodev/lib/Python': dlopen(/Users/tuchang/.local/share/acli/1.3.4-stable/plugin/rovodev/lib/Python, 0x000A): Symbol not found: (_mkfifoat)
Referenced from: '/Users/tuchang/.local/share/acli/1.3.4-stable/plugin/rovodev/lib/Python'
Expected in: '/usr/lib/libSystem.B.dylib'
✗ Error: failed to execute the command
1 comment
Jovana Dunisijevic
October 23, 2025
Hey @tom td
Sorry for such a late response!
This typically happens when the Rovo Dev CLI (or its embedded Python) expects a newer version of macOS than the one currently running on your device. There is a system library incompatibility. The latest Rovo Dev CLI releases require macOS 12 (Monterey) or later.
Let me know if you were able to upgrade recently or if the problem has been resolved?
Jovana
