We have enabled slack connector following
https://support.atlassian.com/organization-administration/docs/connect-slack-to-rovo/
I have also authorized Slack and it shows in my Confluence as connected.
We are unable to find/prompt any messages using Slack as the data source, even public channels.
Hi @Raymond Ko - could you please share your cloud id so I can have our dev team to help investigate? Thank you.
Hello @Raymond Ko ,
I notice that messages are being Ingested. Are you not seeing any search results ?
Hi Yousuf, Slack is coming up in the Confluence Search results now.
However, in ROVO, the same prompt is not yielding any results from Slack. Do you know why this is the case?
Hey @Raymond Ko , would you provide a screenshot of the page where you didn't get any Slack results? If there's anything sensitive on the screenshot, please mask them :-)
This is from the Confluence search:
This is the same prompt from ROVO:
Thanks @Raymond Ko , looks like the Rovo Chat is not working, we will investigate and update you later. Thank you for your patience!
Hi @Raymond Ko , currently Slack integration only works in search. We are actively working on enabling Slack in chat as well and it will be supported soon. See the following link for details. https://support.atlassian.com/organization-administration/docs/connect-slack-to-rovo/.
Thanks. So I understand this clearly, ROVO the product is both search and chat? Right now the slack connector allows search results to show up in search and will be enabled soon in ROVO?
