  • Community
  • Q&A
  • Rovo
  • Questions
  • WARNING: The configured Atlassian site could not be found with the │ │ provided credentials. │
DG Worker
October 6, 2025
Starting acli rovodev run...
│ WARNING: The configured Atlassian site could not be found with the │
│ No Atlassian sites with active Rovo Dev SKU found. │
Failed to start Rovo Dev CLI:
Rebekka Heilmann _viadee_
Hi @DG Worker
Rovo Dev first needs to be activated on your Atlassian site, following these instructions: Turn Rovo Dev features on and off | Rovo | Atlassian Support
If you (or your Org Admin) don't see these options on admin.atlassian.net, Rovo Dev is not yet rolled out to your site.
Also, you need the correct combination of Site ID and credentials.
