Change default repo location
James Carroll
January 20, 2014
Whenever I clone a repo from BitBucket to my local system, Sourcetree assumes that I want to store the local copy to my "home" directory( c:\users\<my name>\Documents\<repo_name>). That's not where I have all my git repos, so I have to navigate to where I want it to be stored. This creates two frustrations:
1. I can't figure out how to change the default location so that I don't have to navigate at all.
2. Once I'm done navigating Sourcetree has "forgets" the repo name so I have to add it back in.
Is there a way to set the default folder in SourceTree so that I'm not as frustrated?
32 votes
Seth
January 21, 2014
Have you tried setting the "Project Folder" in Tools > Options > General > Misc? I don't know if that is what that option sets, but it seems like it might.
James Carroll
January 21, 2014
That was it! Thanks!
Łukasz Augustyniak
November 15, 2014
Thanks! Works for me too :)
JC
May 14, 2015
Thank you!
Lucy
July 14, 2015
Note that for macs this setting is under SourceTree > Preferences > Misc section but is still called "Project Folder"
Like CyxouD likes this
jmccleery
November 10, 2015
Exactly what I was looking for!
Joaquim Barrera
April 1, 2016
OMG so obvious... smile
scottgoddard June 6, 2016
I completely missed this also, despite many looks! Thanks smile
amitkdr
August 29, 2016
So what does one do if one's work-laptop is tiny and the misc folder is below the fold and there's no scroll bar on that option window? I can't get to that option and can't pretend to have a higher resolution!
Deleted user April 9, 2019
Works for me Too - so amazing which I would known this long ago
19 votes
Tornike Gelashvili
In a new version of sourcetree (v2) the setting is called "Project folder:" and it's located under Tools > Options > General > Repo Settings.
vsshs
August 14, 2017
Like 4 people like this
Jeramy S January 23, 2020
This is still accurate in V 3.3.6 (Jan 2020).
Moeez_Ahmed
March 11, 2020
Thank you. This information helped me.
titiman
April 14, 2021
Thank you. Confirmed the same for v 3.4.2 on Windows as of April 2021.
pradeepradyumna
May 27, 2021 edited
In the year 2021, Source Tree Version 3.4.4 for Windows.  you can find it under
Tools -> Options -> General -> Repos Settings
Project Manager
January 28, 2020
I am unable to modify this using the BitBucket GUI for macOS (version 4.0.1).
There is no button available to choose a different default directory...
Does anybody know how to modify this using command line?
