I got the latest version of sourcetree yesterday. (April 4th 2018) I am unable to push my code changes to remote . I see the below error. How ever I have my password set up in sourcetree for my bitbucket account.
Please help.
git -c diff.mnemonicprefix=false -c core.quotepath=false -c credential.helper=sourcetree push -v --tags --set-upstream origin refs/heads/feature/branchName:refs/heads/feature/branchName
Pushing to https://sdodderi@bitbucket.org/domainName/projectname.git
fatal: could not read Password for 'https://sdodderi@bitbucket.org': Device not configured
Completed with errors, see above
Downgrading to version 2.7 got me back and working until the issue can be sorted out. Check out the Download Archive.
For me only 2.7 worked - 2.7.4 was no good
This answer is not acceptable anymore. We are in 2020 and we should not have to downgrade to 2.7 as being in 4.0+.
Please upvote for visibility: https://community.atlassian.com/t5/Sourcetree-questions/REOPEN-Device-not-configured-error/qaq-p/1528957#M37492
My fix, which appears to be working on 2x Windows machines and 1x MacBook Pro, is to setup SSH and remove all password related things (such as keychain in MacOS). This has worked for me for a couple of months now.
Same issue in february 2019 !
Is there a chance to have an update that fix that pb ?
(3.1.3 v)
Same problem here with 3.1.1 (213) when I want to finish a feature.
BTW: How did you get 3.1.3? Update tells me I'm on the newest Version...
Same problem here with 3.1.1 on a MAC, I also have the same problem on a windows 10.
same problem 3.1.2 on MacOS
same problem with 3.2.1 on MacOS Mojave
Is there anybody on atlassian ?
no answer !!!
Same issue with 3.2.1 on MacOs Mojave
I'm having same issue with 3.2.1 on macOS Mojave.
I'm having the same issue (with 3.1.2 (216)). It seems to only happen when I've pushed the feature branch to the remote. I did found a workaround, though. Just set your HEAD to develop and use 'Merge' instead.
Cmon! I'm in 2020 with version 4.0.1 (234) on macos 10.15.7 and still having same issue. Click on "Convert to ssh" just make "error-bump-sound" without any errors.
FIX IT (09/2020)
All the the answers here are wrong... You shouldn't NEVER do something like that:
https://username:PASSWORD@Bitbucket.org
SOLUTION
All you have to do is:
- Go to Sourcetree -> Preferences -> Git
- You will have the section "Git Version" with 2 options: Reset to ebedded Git and Use System Git
Sourcetree use the Ebedded git for default.
Click on "Use System Git" and.... Fixed!
Follow me on:
GIthub
Twitter
"Use System Git" works for me. sourcetree 4.1.6, macos 10.15.7
For me too!
Thanks PeterDev.
I've used to be having the same issue and fixed it by right-clicking the repo in the main window and selecting 'Convert to SSH' -> so was my Github account connected through, using SSH. Restarting the app is also encouraged after doing so.
It works!! Thank you so much
Worked for me. Thank you Dorian!
Thank you so much 🎉
Worked for me too!
I tested many of the solutions that are explained here, but finally the only that really worked for me was this (for Mac users only):
https://gist.github.com/RockinPaul/6b012b106c4175469ee39bde12fb67f7
I did the following steps to get my Mac OS Sourcetree working with a GitHub Private Repo:
Now creating, finishing features, pushing changes etc. work
@luckyclan @Virl I downgraded to 2.7.2 and I can now use the finish feature. I guess I will just stick to 2.7.2
Worked for me
I just updated to version 2.7.5 (176) and its happening again.
I would really like to trust SourceTree not to interrupt my work day, but I'm getting pretty tired if having to back out the version
@Manju restarting Mac did not help me.
@Ryan Sherman thanks, downgrading to version 2.7 fixed all the problems.
@hawkun @Soumyadeep Ganguly You guys also might want to try downgrading sourcetree to version 2.7
This worked for me.
I am not sure what is going on but I made sure everything was set to basic / https
the oauth / ssh VS basic / https WAR continues
@Sreelakshmi DodderiThanks, upgrade to 3.0 resolved this issue.
any update here? I am also facing the same problem in Macbook. Now am at a stage where i cant push anything
Using Visual Studio Mac with Source Tree 3.1.2 My machine already has ssh keys, etc., for other projects on BitBucket
I had a local repo for a project that was mature enough to put in the cloud. So I created new bitbucket repo. I could not get the instructions for Visual Studio Mac to add remote repo to work, so I opened Source Tree and opened the local repo.
Then I went to Menu -> Repo Settings and then Remotes tab. I added the URL of the newly created Repo. But, here is the catch:
The URL of the page you create will be something like:
https://bitbucket.org/teamname/reponame/src/
That is not correct, but SourceTree will accept that URL. And then fail (with the error in this issue) when you try to push to it..
What you actually want is:
I encountered this issue when trying to use the "finish" action on a release branch.
For some reason, the same action works for a feature branch.
I tried some of the answers above.
I tried changing my account settings to SSH. There's a button there that says "connect your account". This opens a mini browser that simply does nothing but directing you to bitbucket's login.
Only other option for you beside surfing the web is clicking cancel, which obviously not connects the account to SourceTree.
Could only connect via basic method, but this didn't change anything.
I tried some other solutions from the threads provided by other people in this thread and nothing works.
Only solution worked for me was the last thing I wanted to do, and is downgrading to 2.7.2.
And to be honest? This is the exact same version as 2.7.6 but without bugs. There's nothing new that worth that headache so just downgrade to 2.7.2.
There is a separate thread, and somebody published working workaround:
Try change repository link format from "https://username@bitbucket.org" to "https://username:password@bitbucket.org"
Yes, it is not safe, but it is working!
Another thread is here:
Bug is still not fixed.
But there is a workaround: go to Sourcetree>Preferences>Accounts, select account, tap Edit and change protocol from HTTPS to SSH. You have to generate SSH key and add it in bitbucket profile settings to make it work.
The interesting thing is that everything works fine on other computer in our office, no need to change to SSH there. It uses exactly the same repository settings, but different user profile.
Related:
Still not working ...
We identified the issue here and hot fixed it over the weekend. Please update the build to 2.7 (167) and you should be good with this version. Sincere apologies for the inconvenience and appreciate the patience.
Manjunath
Sourcetree Mac Developer
Hi Manju,
With build 2.7 (159) I got this error
Something went wrong. one or more parameters required to renew token is nil.
With build 2.7 (165) I got this error...
With build 2.7 (167) I get this error...
The remote service said: 'The operation couldn’t be completed. (SDNetDomain error 7.)'
I tried the archive build to 2.7 (152) and got...
So command line it is!
Best,
Som.
Hi @Som Shahapurkar,
Can you confirm the remote host you were trying to connect and whether the account was added to Sourcetree?
Manjunath
Hi @Manju,
Thank you for your prompt response.
Seems like when the account was added to Sourcetree, it fails.
I deleted the account and used 'Clone in SourceTree' from bitbucket web, now it works fine.
Som.
There seems to be some oddity with keychain and macOS that causes this issue. I faced the same a couple weeks back and just had to restart to my Mac to get it fixed. Give it a try and let me know If it works for you. If it doesn't, please remove the account and add it again. You can enable a debug menu from Preference window -> Advanced tab and set debug logging and enable auth logs to help us get all the logs in case of failures.
Manjunath
I have tried everything you mentioned and can't get it to work again. I have the same exact issues after upgrading yesterday. I have disabled 2FA on GitHub, reset by personal access token, remove the account and added it again, remove my github keychains, reset my machine, tried basic, oAuth with SSH and HTTPS and nothing has worked. Please help I am starting to lose my mind!
