Does SourceTree have an interface for git-hooks?
Swift Capital
Not much else to be said. We'd like to work with git-hooks without having to use the command line.
Balázs Szakmáry
April 8, 2015
There is no option for this in SourceTree. Just copy the hooks into the /.git/hooks/ folder of your clone.
Swift Capital
I'm accepting this answer, although I'm also putting in a suggestion for SourceTree.
Like 3 people like this
Chris H (OG) October 1, 2018
SourceTree Mac 2.7.6 here: `/.git/hooks/` is not working anymore.
GeroHerkenrath
October 2, 2018
Just in case, Chris: Are you sure you set the hook script(s) to executable (chmod +x)? I just got here via google because I forgot to do exactly that.
git throws a warning (at least 2.17.1 does) on the console if it sees a script but it isn't set to x, but unless you have the "Command History" shown in SourceTree you won't see that. Was scratching my head for a bit why my very simple pre-commit wasn't called.
ChristoKiwi
October 2, 2018 edited
@GeroHerkenrath Yup, tried making the hook script executable 👍
Using GIT version: 2.17.1
Chris H (OG) November 5, 2018
Oh my.
@GeroHerkenrath I had run chmod +x on the hook file but just now also tried opening up the file with chmod 0755
Bingo, hook is now picked up.
Thanks for getting me on the right path at least!
