External diff/merge tool does not launch
85e72acf18064 June 3, 2019
After update to 3.1.3 version of sourcetree I can't launch external diff/merge tool.
I've tried everything that I could find, but it didn't help much.
I use IntelliJ IDEA tool and set it as follows in Tools -> Options -> Diff -> External Diff/Merge section:
1.jpg2.jpg.gitconfig file:
[diff]
tool = sourcetree
[difftool "sourcetree"]
cmd = 'C:/Program Files/JetBrains/IntelliJ IDEA Community Edition 2019.1.3/bin/idea64.exe' diff $LOCAL $REMOTE
[merge]
tool = sourcetree
[mergetool "sourcetree"]
cmd = 'C:/Program Files/JetBrains/IntelliJ IDEA Community Edition 2019.1.3/bin/idea64.exe' merge $LOCAL $REMOTE $BASE $MERGED
trustExitCode = true
When I try to launch external diff tool by RMC -> External Diff in Process Viewer I see the following:
But when I use git command line:
press Enter and the tool is opening.
Do anybody know what to do with that?
UPDATE
I've tried to change diff/merge tools to another one but error was the same. I've tried to find all gitconfig files and Total Commander gave me few:
I noticed that when I change anything in tools > Options none of the gitconfig files are changed and it looks like SourceTree stores settings in a different file.
My setting from the Git tab are:
I've tried to reinstall SourceTree - did't help
85e72acf18064 June 9, 2019
The problem was because of HOMESHARE system environment...
In this topic I found that SourceTree uses the following rules to locate your global git config:
  1. HOME, if defined in the global Windows environment (NOT in .profile or similar, only Bash sees that)
  2. HOMEDRIVE + HOMEPATH as a first fallback
  3. USERPROFILE as a last resort
My HOME variable had a nonexistent path. Although my USERPROFILE varibale was ok the SourceTree didn't want to look for .gitconfig file int it.
Martin Egholm
November 16, 2023
Still a solution today 👍
Nikhil Agrawal
February 1, 2024
I'm having the same issues. My fix was in my .gitconfig file. The path to my diff tool wasn't set correctly for some reason.
G B September 19, 2019
In windows 7 external diff suddenly stopped working for no apparent reason.
I upgraded to 3.2.6 to no avail.
In the end it were the wrong quotes (replace ' by ") in the .gitconfig file in my home dir (cd ~ in terminal)
wrong .gitconfig file:
[diff]
tool = sourcetree
 Correct .gitconfig file (see the usage of " instead of ' at the cmd lines:
[diff]
tool = sourcetree
cmd = "C:/Program Files/JetBrains/IntelliJ IDEA Community Edition 2019.1.3/bin/idea64.exe" diff $LOCAL $REMOTE
Mike Corsaro
June 4, 2019
Hello! I think this might be caused by the .gitconfig being configured for the system-wide git rather than embedded git. Could you try switching from embedded git to system git under Options > Git (or verify it's already using system git)?
85e72acf18064 June 4, 2019
Hi, thanks for reply! I've tried switch to embedded git, try use extrenal diff, then back to System git and it didn't help. I've updated my question.
Off-top: It's strange that the latest version from official site is 3.1.2 that wants to update to 3.1.3 after install
85e72acf18064 June 5, 2019
deleted
Mike Corsaro
June 5, 2019
Could you check if the setting "Allow Sourcetree to modify your global Git and Mercurial config files" is checked under "Options > General"?
Yes, it is checked. Looks like I found a file that changes it is
C:\Users\MyUser\AppData\Local\Atlassian\SourceTree.exe_Url_knb5dzyr40klo0lpr3rjuzjrpxfshf5c\3.1.2.3027
I looked for all files that contains ( diff \"$LOCAL\" \"$REMOTE\" ) on the system disk, with the Total Commander search tool and it found only the file above
