×Hi
I have just made a pull of the commits of mi dev branch and one of the add several files
but when I open the solution in Visual Studio I don't see that files and the repo folder neither
Any idea Please?
regards
The reason you are not seeing the files is because you have the branch dev checked out and the missing files are on feature/Ficha(?) branch. In order to see the files you either have to merge the feature branch into your dev branch, or check out the feature branch.
