Git Flow for SourceTree on Windows doesn't work
Karim Maassen June 13, 2013
SourceTree outputs the following when I try to initialize Git Flow:
sh.exe C:\Users\[user]\AppData\Local\Atlassian\SourceTree\gitflow_local\gitflow\git-flow init -d
flags:FATAL unable to determine getopt version
Completed with errors, see above.
What is going wrong?
Karim Maassen June 16, 2013
Hi Steve,
We use 0.9.4.0 for Windows.
It appears though that the issue was a faulty git flow installation prior to the SourceTree install. I removed all git flow installation data and reinstalled SourceTree (after removing all SourceTree data as well)
After reinstallation of SourceTree, all is woorking fine! :)
stevestreeting
June 13, 2013
What version of SourceTree are you using?
Help us plant more trees
