How do I change what commit is considered 'master' on a branch?
Justin Turner
November 22, 2018 edited
Pretty new to source tree, this is probably a really simple issue, but a recent commit/push broke our scene. I tried reversing the commit, but that gave an error, so I ended up 'checking out' a prior working node and working from there. I'm having trouble getting the 'origin/master' 'origin/head' 'master' tags to move to the most recent node. (see red outline in image)
The scene was working on every node before that merge (the current 'master' node).
The scene is also now once again working on my current 'HEAD', but I'm not sure how to set that as the 'master' so to speak
Any thoughts on how to resolve this?
Community moderators have prevented the ability to post new answers.
Post a new question
Justin Turner
May 6, 2019
I can't remember exactly how I resolved this particular issue, but I definitely recall creating a new branch and I feel like the issue wasn't present there, so I feel like I may have ended up making the new branch my primary branch and deleting the old one. Either that, or the rest of Mike's suggestion may have worked for me... I don't recall for sure.
Ethan Thompson
April 28, 2019
Did this solution work for you? I did exactly as Mike instructed and every time I load my project its the same master branch it was before. Not the 'Temp' I was trying to revert back to. I've created 3 new branches now that I cant get rid of and I'm still having the same problem
Mike Corsaro
December 5, 2018
Hello! The thing you're seeing is known as being on a detached HEAD. To fix this:
  • Create a new branch (hit the branch button)
  • Call it something like "Temp", make sure "Checkout new branch" is checked
  • When that's done, switch back to the master branch (just double click master in the sidebar)
  • Then, right click on "temp" in the sidebar, and click "merge 'Temp' into current branch". This will merge the changes you made on that detached HEAD back into the master branch
  • Your master branch will now have those changes you made (don't forget to push!), and everything should be working again
Post a new question
