How do I disable pipelines in SourceTree
CharlieC
While I appreciate the integration of pipelines in SoureTree it's also a complete resource hog on MacOS and will happily run my CPU at 100% for hours. Is there anyway to disable the reporting so that I don't keep having to close SourceTree?
Manju
August 7, 2018
You can Hide Build status column from the View Main Menu
CharlieC
Thanks! I couldn't find this, though I admit to trying settings and right-mouse clicking on the interface.
Do you know if this will reduce the CPU load that the integration, hopefully only currently, triggers? Guess I'll find out when I make my next push.
Paweł Philipczyk
October 22, 2019
Do you know why does this take up so much CPU?
