×How disable option "Help improve sourcetree by sending data about your usage" after installing SourcetreeEnterpriseSetup_2.6.10.msi by default.
What I tried?
Tried to disable option in C:\Users\XXXX\AppData\Local\Atlassian\SourceTree.exe_Url_yjhzxxhcu2ommegrdorjf3q1oqllqxiq\2.6.10.0\user.config
<setting name="AnalyticsDisplayOptIn" serializeAs="String">
<value>False</value>
</setting>
But if I go for new installation this folder won't available C:\Users\XXXX\AppData\Local\Atlassian\SourceTree.exe_Url_yjhzxxhcu2ommegrdorjf3q1oqllqxiq
If you re-install/update Sourcetree in the same location, e.g. in program files then the C:\Users\XXXX\AppData\Local\Atlassian\SourceTree.exe_Url_yjhzxxhcu2ommegrdorjf3q1oqllqxiq folder should not change after updates.
Sourcetree copies the previous versions user.config when it updates.
Is it immediately sending the information to Atlassian by enabling the option and click next or sending the info after completing the initial setup
Sourcetree will disable the analytics feed after the wizard completes.
