How to filter commits by author?
dylan-nicholson
The list of commits for the current branch still often makes it hard to see just your own commits, if you've merged in other branches etc.  In fact what I'd really like is a way just to see commits made DIRECTLY to the current branch, and exclude anything changed via a merge.
5 votes
Duane Mattos
There is a feature request: BSERV-10875
samlachance
September 17, 2019
If anyone discovers this thread looking for a solution, you can try the solution outlined here:
https://superuser.com/questions/900590/how-to-filter-commits-by-author-in-sourcetree
There's a custom search window if you go to View->Search View
Dean Pulsifer
May 12, 2020
The problem with this solution it that it searches all branches.  I think the request is to search a specific branch for commits from an author.
Like # people like this
Ana Retamal
June 9, 2017
Hi Dylan, this feature is not currently available but you can submit your idea at jira.atlassian.com by clicking the Create button.
Hope this helps!
Ana
