First off, I am not using command line git at all. I am only using SourceTree's gui interface. I would prefer to solve my problem this way; if possible.
Somehow, my submodule has become corrupted. Attempting to fetch or pull gives me the following error:
I haven't found any answers for this particular problem. I am fortunate in that my remote master is ok, 100% up to date, and I have no local changes. So, I think the easiest way will be to just fully reset my local submodule.
However, I can't figure out how to do so.
I considered trying to remove my submodule and then re add it. However, I have had problems with that in the past, and so am gun shy.
I found handfuls of posts about resetting to a specific commit. However, the SourceTree gui is failing to populate my history because of this error.
Any help would be appreciated
Thank you
