In SourceTree, how do I squash commits?
Andrew Drexler
September 18, 2013
Your marketing blurb refers to being able to squash commits by drag and drop. I've dragged. I've dropped. No joy.
What's the trick?
18 votes
Jeff Thomas
September 24, 2013
Right-click on the parent commit and select 'Rebase children of <sha> interactively'. After that, you'll be able to drag and drop to squash commits.
KieranA
September 25, 2013
As Jeff says, this is how you interactively rebase in SourceTree. From here though, you'll need to drag and drop the commits (represented as rows) onto one another in order to squash them.
Like • 2 people like this
Ludwik Szymon Janiuk
August 23, 2014
The problem that I and seemingly others here are facing, is this: imaginge three commits, A->B->C (chronological order). Now, say I'd like to squash C into B. Judging from the answer here I should right click on B, select "rebase children interactively", and then be able to do it. But here's the problem: When I do that, only the children of B (aka, C) are shown in the dialog and available interactive rebasing. To do what I originally wanted to do, squash C into B that is, I actually have to right click A, choose, "rebase children interactively", and then B and C show up in the window, I can squash C into B, press OK and it's done.
My question is, is this a bug or is this how it's supposed to be? And if you really want it that way, what's the reasoning behind that decision?
Or, am I just missing something? ;)
Like • 8 people like this
timlegrand August 31, 2015
+1
Like • Eugene Porubaev likes this
Adam Gall
September 13, 2015
@Ludwik Szymon Janiuk That's just how git works. Imagine your scenario: ``` * f5ac8a9 - (HEAD -> master) C * 8667061 - B * 2d19dc0 - A ``` To squash C into B, you would type in `git rebase -i HEAD~2`, which is equivalent to `git reabse -i 2d19dc0`, which would output: ``` pick 8667061 B pick f5ac8a9 C # Commands: # p, pick = use commit etc. ``` So to answer your question, SourceTree is most likely behaving this way on purpose, because it's mimicking how git works.
Like • Martina Rossi likes this
9 votes
ash_cooleman
December 3, 2014
SourceTree 2.0.3 OSX:
  1. Select oldest commit (of the multiple commits) you want to modify aka rebase
  2. Repository -> Interactive rebase
  3. Right-click a commit and select the option "Squash with previous commit..."
edit: Atlassian have a great post on this
marjanvenema July 18, 2016
Thanks for the linked post. It was extremely useful!
Like • Rollin McCarty likes this
Dan_Ash
December 3, 2017
Gift keeps on giving.  Thank you.
3 votes
Wendell Thompson
October 22, 2014
For the Windows version a good workaround is to use the "Terminal" button and execute git commands manually.
git checkout [destination branch]
git merge --squash [source branch]
Rajesh Bachani
November 22, 2016
Still not available for Windows?
Gabriel GM
November 25, 2016
I'm using Windows Version 1.9.6.1 and it is available.
Marcel Bradea January 29, 2014
When clicking the option on the same commit where the 'master' branch is nothing happens at all (dialog does not show up). It only works when performed either on the commit prior or the one after, which makes no sense at all. Usually you want to squish the commits you've been working on in your branch, which directly stem/root in the latest commit on 'master. Is this a bug or a design decison I am misunderstanding?
Jeff Thomas
January 29, 2014
You'll want to click on the oldest parent commit that you'd like to rebase to. This will allow you to squash any children commits from that point. The graph in SourceTree is upside down, where the parent commits are lower and children commits higher. Does that help explain it? If it doesn't, could you provide a screenshot of what you're trying to do and I might be able to help further.
Darko Damjanovic
July 25, 2018
Yes, this seems to be a (conceptual?) bug. To test: please branch from master and branch named "dev". Then create multiple commits on "dev". Then try to squash _all_ commits from dev into one. It does not work, because you would need to do the squashing from the commit _before_ the first commit on dev. But there is no commit _before_ the first one. So it's not possible to squash all commits of one branch into one commit with Source Tree as far as I can see. (Edit: I found an ugly workaround...)
Andrew Drexler
September 24, 2013
Thank you for your response!
I am using the Mac version. The site info indicates squashing can be done with drag and drop. I've tried every combination of drag/srop I can think of without success. How do you do it?
Thanks again
Jeff Thomas
September 24, 2013
Are you using Windows or Mac OS X?
I don't believe the squash commits functionality has been added in the Windows version yet.
Jeff Thomas
September 24, 2013
This feature is available in the Mac OS X version of SourceTree, but I don't believe it's made it to the Windows version.
Are you using Mac or Windows?
