Is there a way to create a pull request from SourceTree without redirecting to Bitbucket Web??.
I am using a Bitbucket without SSL. Whenever I create a pullrequest from SourceTree it redirects to HTTPS url and will not be able to connect to Bitbucket web. I know a self signed certificate or a real certificate required to work SSL.
Is there any other way to create the complete pull request from SourceTree itself?
Hi Anoop, at the moment it's not possible to create pull requests without redirecting to Bitbucket. If you'd like that to be possible, you might be interested on voting for this Feature request SRCTREEWIN-7654.
You mentioned that when you tried creating a pull request from SourceTree you're not able to connect to Bitbucket:
Best regards,
Ana
