×Is there a way to integrate SourceTree with Stash or BitBucket, such that a pre-push git-hook could be specified server-side, and automatically installed on SourceTree clients?
This is not about pre-receive git-hooks. We're specifically looking for a way to deploy a pre-push git-hook to everyone on the team.
The usual pattern for this is to commit the hook to the repository (e.g. hooks/pre-push
) and then get each team member to symlink (or copy) it into their .git/hooks directory:
ln -s hooks/pre-push .git/hooks/pre-push
There is no way to enforce that a git hook runs on the client-side, you must rely on your developers to install it themselves (I usually document the process in the repositories README) and, for important hooks - e.g. running tests or lint tools - run them on the server as well.
I'm accepting this answer, although I'm also putting in a suggestion for SourceTree. We're always looking for ways to utilize team settings to enforce standards.
As Tim writes, this is an unsolved problem, normally addressed with conventions.
With the Commit Policy Plugin, we use a different approach to install dynamically generated client-side commit-msg scripts:
So far, it works fine. (As the scripts are dynamic, we can't include them directly in the repo content.)
We're looking to enforce "all unit tests and integration tests must be run before a push". While we have these running on the server to, we'd rather our devs be pro-active then re-active when it comes to hunting down problem areas.
I don't believe there is. Out of interest, roughly what do you want to do in the client side hook?
