Partial stage/unstage operations fail with cryptic error
Nathan Gray
When I try to stage or unstage part of a file using the Stage Hunk or Stage Selected Lines button I get the following error:
'git apply' failed with code 1:'error: (null): does not exist in index
The last single quote appears on its own line.
I have tried running 'git fsck' on the repo and didn't get anything unusual.
24 votes
Jasmine Hegman
October 10, 2012
Follow up, this is fixable by setting Show Whitespace to Ignore Whitespace. Then the apply works. It appears that some of the time the line numbers from whitespace changes affects things negatively. This doesn't always happen, but at least for me this time it fixed it. Hope it helps someone else! :)
Deleted user November 19, 2014
Still have this issue in 2014, but "Ignore Whitespace" helped. Thank you!
ollietreend
March 27, 2015
Yep - this issue still exists, and this still seems to fix it. For those who aren't sure where the 'Show Whitespace' option is located - look for the small cog icon in the top right corner of the "File Status" view, to the right of the search box. The option is in there.
Ryan_Draper
October 27, 2015
I found the reverse fixed my problem, setting from Ignore to Show. Whatever works I guess.
Like • Sreeram Ramakrishnan likes this
Michael Cote
January 26, 2016
its 2016 and this is still an issue...
s g
January 26, 2017
Where is "setting Show Whitespace to Ignore Whitespace"?
RichH January 27, 2017
s g
January 28, 2017
OK, so that not helps.
RichH April 20, 2017
You're right, that didn't. Not sure what happened there. Let's try again.
Luv4sko
Petr Nagy
June 11, 2020
With either Ignore whitespace or Show whitespace checked, this issue still exists in 2020. I'm sorry but how hard can it be to fix?
Like • 2 people like this
4 votes
Simon Dingley
The only way I could get around this was to stage all changes to file then unstage the chunks I didn't want to commit.
December 22, 2020 edited
This is still an issue in December, 2020; disappointing to say the least!
Anyway, the fix for me was to switch to show instead of ignore.
Carsten Wegner
May 11, 2014
Might also be the character encoding. If you set encoding to e.g. UTF-8 in SourceTree, but save the file in ANSI and have e.g. german Umlaut characters in it. Make sure to use consistent whitespace, character encoding and line-end handling.
Johannes Luber
October 6, 2014
I can confirm this. I merely changed the encoding for a file from ANSI to UTF-8 and now it works. Also I noticed that in ANSI, umlauts weren't shown correctly, merely as the question mark placeholder glyph.
Jeremiah Small
Switching to Ignore Whitespace fixed this for me.
Daniel Rice
February 16, 2014
How do you switch to Ignore Whitespace?
Simon Dingley
Above the diff view there is a cog icon, click that and you will see the option to show or ignore whitespace differences in the view.
Joel Stein
March 26, 2013
I'm getting this same problem when trying to "Stage Hunk". I don't know how to do the suggested fixes. Will somebody please enlighten me?
Mark Turner
July 16, 2012
I'm also having the same issue:
'git apply' failed with code 1:'error: attak_game.js: does not exist in index'
When trying to "Stage Selected Lines"
Nathan Gray
It fails on any file in any repo on my machine. Doing "git add --patch" works properly, as does using the equivalent feature in Tower.
Actually I just figured it out. This feature breaks if you have diff.mnemonicprefix set to true in your git config.
Thomas Harold
January 4, 2016
Try adding the following to your ~/.gitconfig
[apply]
    whitespace = nowarn
Does this allow merges to complete successfully, or just suppress the error and cause the merge to mess your file up? :)
blueblau September 27, 2017
I tried the above, restarted my machine, and got this slightly different error...Skærmbillede 2017-09-27 kl. 09.11.59.png
DimitryDushkin
November 25, 2014
Problem still presents.(
blueblau September 26, 2017
Still... 5.5 years later.
Joshua Marsh
April 2, 2014
This thread is quite old, but I just wanted to stop in and say I still see this issue.
Gotta be line-ending-related; I'm attempting to stage hunks/selected lines on a Windows machine after the source files were last modified on a Unix machine.
Very irritating issue, and none of the fixes in this thread worked for me.
Tai Lee
March 23, 2014
I see this with "Ignore Whitespace" AND "Show Whitespace". I don't have "diff.mnemonicprefix" set in my gitconfig. As far as I can tell, my file just has UNIX style line endings. What's the cause and fix?
fcorreia
Despite the workaround, this is very annoying. Hope it get's fix really soon.
Sebastian Siedentopf
March 24, 2013
I see this when end-of-line characters are messed up in a file.
Jasmine Hegman
October 9, 2012
Just wanted to add that I too experience this occasionally. Got it now in a file with several different detected hunks, and none of then can work via apply hunk or apply selected lines, nor can they be un-applied. Only fully staging the file as a whole works.
Dennis Cornwell
July 1, 2012
I'm seeing the same error. Unfortunately, settng both my global and local diff.mnemonicprefix setting to false doesn't solve the problem for me.
stevestreeting
March 21, 2012
Can you give some more details about the file you're trying to do this on? This functionality works in all my tests here.
