I seem to be in a bit of an endless loop with configuring my git excludes file in SourceTree.
My global git config is kept in `~/.config/git/config`. My global git ignore is stored next to the config file at `~/.config/git/ignore`. This is the default value for core.excludesfile and as such is detected even when that settings is not defined in my config file.
The problem lies in the fact that SourceTree somewhat randomly will decide that my excludes file needs to be set. It then sets it to `~/.gitignore_global`.
Just trying to understand if theres anything in particular i'm doing that is causing this to reoccur.
First of all:
check your sourceTree global git config in preferences
it's typically set to ~/.gitignore_global
. You might fix this manually and reset this to what is configured in core.excludesfile
If you ask me: it's a bug that this is configured by default. While you can see, the new .config/git global ignore file was introduced in 1.9.x release (refer to git-scm.com/docs/gitignore) it seems to be common practice from the past to change this, like github documents it.
Unfortunatly another default setting will always reset this:
check this and turn it off, I have much less problems without it too.
Feel free to check back the issue tracker and file a bug request for this.
Heads up! Opsgenie's features are moving to Jira Service Management and Compass. Planning your migration? Join our dedicated group for resources and tips from Atlassian and the Community to ensure a smooth transition.
Check it out ↗Online forums and learning are now in one easy-to-use experience.
