I'm trying to clone a repository using git on a Macbook with MacOs Monterey or with MacOs BigSur but when I try to authenticate on terminal, I receive a message:
fatal: Authentication failed for 'https://user@bitbucket.org/******/repository.git", for example
I'm using the correct password and the same command on a Windows environment, and it runs without any problem.
Using sourcetree it works with the BigSur, but I would like to try to clone the repository without using another software.
What can I do?
Thank you all.
