Problems cloning repository from bitbucket
Carlos Delgado Jurado
February 15, 2022 edited
I'm trying to clone a bitbucket repository but after introducing the URL it says that this is not a valid path and if I click on Details it says that the username or password is invalid
If I enter the URL , it shows an error message and this code: fdf9fdb3024a4fcba49a3e83ff0c0ac7
I tried to delete authentication data, adding again the user, refreshing OAuth Token and reinstalling Sourcetree but the problem persists and I think I made it worse because it won't let me push to previously added repositories that worked fine just before trying to add this new repository. It returns remote:invalid username or password, and fatal: authentication failed.
I don't think the provided username and password are invalid, because I can login to bitbucket.
Also if I open the Remote tab, the remote repositories don't appear and my account's picture has a red X that on hover shows this message:
If I click the Refresh button, the red X disappears and the remote repositories appear. This is not a big issue but it probably is related to the previous errors.
4 votes
February 15, 2022
I finally solved it by deleting the passwd file located in: User>AppData>Local>Atlassian>Sourcetree>passwd
And then re-installing and login with credentials (probably re-installing wasn't necessary).
Chris Holmes
February 16, 2022
I only had to delete passwd.  re-install wasn't needed.
Thanks for the fix!
Like • Carlos Delgado Jurado likes this
Ricardo Gamarski
September 13, 2022
I'll try. Thank you!!!
Leon Schmetz
March 17, 2023
Thank you, life saver! I was stuck in the loop and did not find a chance to enter the application key. After deleting the password file, I could!
Evan Anderson
July 2, 2024
This saved me THANK YOU!
