×Created https://jira.atlassian.com/browse/SRCTREE-1669 but I don't think I have the ability to assign to you. Thanks!
Hi Chris,
I've just tried this using your exact same file structure and filenames and have been unable to reproduce the problem you're describing. Could you re-test this? Are you sure there isn't another folder tradinghistory/history which has the same file structure and you're actually trying to rename that a file in that directory instead?
Thanks in advance
Hi Chris,
You're right, JAC is where we have bug reports over at jira.atlassian.com. The project name is SRCTREE and you can assign it to me. Just detail as much as you can and we can go from there.
Not SourceTree is amazing in detected renamed file history, but Git is - and hence every Git client. Check out http://stackoverflow.com/questions/1094269/
