Is there any possibility to connect ST on Mac with Gitlab CE account?
I tried everything, but no luck
Yes, you can.
1) Go to SourceTree Preferences -> Accounts
2) Press Add... button
3) Fill all fields BUT in the "Password" field you must to enter personal access token!
You can create as many personal access tokens as you like from your GitLab profile.
Thanks, but when I give all credentials, still got this:
We couldn't connect to GitLab CE with your (MarekBakalarczuk) credentials. Check your username and try the password again.
Did you create access token in GitLab with all scopes? You must to use it password field. Its look like "W543dfG3zQddsd6kMq29Z"
OK. I did token again and it has proper format.
But still I cannot make an account.
Maybe it is username matter? It has to be a Gitlab CE login or profile user name?
username must be a Gitlab CE login
in my Gitlab i has no two-factor authentication
It was not working for me either. However: After waiting a couple of minutes after creating the access token, I tried again. This time, when I clicked "Save" I pressed it three times in rapid succession (originally, when I clicked it, nothing happened.) Then... it worked.
I'm not sure if rapid clicking made it work or if I just had to wait for GitLab CE to propagate the access token.
