I upgraded to SourceTree 1.9.5.0 last day and check boxes on left side of files in filestatus lists are gone since then.
Here is a picture of what I see currently in filestatus view:
There used to be a check box on the left side of each file which allowed me to switch single files between Staged and Unstaged lists very fast.
Is there anyway to get the check boxes back like previous versions?
It was deliberate according to the response from Atlassian in the related JIRA issue: https://jira.atlassian.com/browse/SRCTREEWIN-5947?focusedCommentId=935927#comment-935927.
In "split view staging" mode the checkboxes are missing, but in "no staging" mode they are available.
Using "space" as a shortcut works, but is not documented. The official shortcut is "Shift + Alt + C" according to the popup menu, which is quiet to long for such an often used command ...
I want the checkboxes back!
Has to be a mistake. I can live with the absence but it's bothersome. That benefits no one.
Space keyboard button almost works, just it looses focus after pressing key, so I need constantly switch between keyboard and mouse (you can get back focus with like 20 tab key presses, but well...)
Press
SHIFT + ALT + C
This did it, quickly close it before it crashes so that it saves the settings, re-open in full glory
This switches to a different view, though. (Split view staging / No Staging)
20 Jul — 12 Sep. Sourcetree support is titally useless!
You may use version list, to find version that still works (1.8.3 for example).
I immediately update sourcetree after every update notification hoping that the checkboxes are back. But in vain
OMG I thought it was just me - this screws up everything I have workflow wise. Give me back my checkboxes grrrr
Definitely want the check boxes back... Noticed it right away.
I see that Atlassian still has not been able to come up with an update that is not significantly worse than version 1.7 (in the Windows versioning) which I am still running.
I encourage everyone with problems to downgrade to this version, which I consider the final version of SourceTree for my purposes.
Or find your personal favorite here:
https://www.sourcetreeapp.com/update/windowsupdates.txt
A mitigating factor: using SPACE for "checking/unchecking" those removed checkboxes still works. However, I find the visual confirmation of the checkboxes an important think and wish the checkboxes return.
I wonder if 1.9.5 is an alpha release? The version in the update dialog box said "1.9.5 >a" for me, while 1.8.3 did not. Also, there's an item in the Tools menu, "Test - notifications" which appears to launch some testing code.
Yeah I noticed that today too. Weird that they're gone.
