SourceTree bookmarks panel seems stuck at 50% width after I let SourceTree update itself. I can't drag the window pane to resize it. And when hidden with Hide Bookmarks menu item, the project view is only 50% wide of the window and is stuck on the left.
1.6.16 fixes the problems above, you might neef tot do show hide bookmarks after the upgrade
I think this issue was tracked here: https://jira.atlassian.com/browse/SRCTREEWIN-3392
For me, showing the bookmarks, then resizing them and then hiding them again fixed it.
Works for me. But I had to close/open sourcetree several times. Very slow response and sometimes freezes when showing/hiding the favorites panel..
I think you are experiencing this: https://jira.atlassian.com/browse/SRCTREEWIN-3274. Workaround in the JIRA item.
Same here after upgade to 1.6.15. I also got the error message in the Update Summary @fperezr had.
Can confirm here as well. Luckily only some members of the team updated.
This happens to me as well. This was not a good way to start Monday; I now have to figure out how to fix SourceTree rather than actually doing any work.
Same here as well for our whole team after upgrading to 1.6.15 (win)
Same here for our whole team after upgrading to 1.6.15 (win)
Same problem here: - SourceTree bookmarks panel seems stuck at 50% - after having upgraded to version 1.6.14 and final window is an error
