SourceTree crashes and I get this error when trying to clone a repository. Happens with a number of different versions. Any clues?
ERROR [2021-01-08 15:40:21,599] [1] [SourceTree.Analytics.Crash.BugSplat.CrashAnalyticsService] [DispatcherUnhandledExceptionHandler] - DispatcherUnhandledExceptionHandler for [Sourcetree, 2.5.5.0] called with [System.Windows.Threading.Dispatcher, System.Windows.Threading.DispatcherUnhandledExceptionEventArgs]
System.Exception: An OnError occurred on an object (usually ObservableAsPropertyHelper) that would break a binding or command. To prevent this, Subscribe to the ThrownExceptions property of your objects ---> System.ArgumentException: Absolute path information is required.
at System.Security.Util.StringExpressionSet.CreateListFromExpressions(String[] str, Boolean needFullPath)
at System.Security.Permissions.FileIOPermission.AddPathList(FileIOPermissionAccess access, AccessControlActions control, String[] pathListOrig, Boolean checkForDuplicates, Boolean needFullPath, Boolean copyPathList)
at System.Security.Permissions.FileIOPermission..ctor(FileIOPermissionAccess access, String path)
at System.Environment.InternalGetFolderPath(SpecialFolder folder, SpecialFolderOption option, Boolean suppressSecurityChecks)
at SourceTree.ViewModel.CloneNewDialogViewModel.RefreshDestinationDefaultPrevSource(String prevSrc, String newSrc)
at SourceTree.ViewModel.CloneNewDialogViewModel.<CheckSource>d__201.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at SourceTree.ViewModel.CloneNewDialogViewModel.<<-ctor>b__53_3>d.MoveNext()
--- End of inner exception stack trace ---
at ReactiveUI.RxApp.<>c__DisplayClass5.<.cctor>b__2()
at System.Reactive.Concurrency.Scheduler.Invoke(IScheduler scheduler, Action action)
at System.Reactive.Concurrency.DispatcherScheduler.<>c__DisplayClass1`1.<Schedule>b__0()
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
It's similar, but I don't see a solution there. I get the same problem regardless of what version I'm using. I see the same thing with 3.4.1.
I am having the same issue. This is complete error report thrown after source tree crashes
System.ObjectDisposedException
HResult=0x80131622
Message=Cannot access a disposed object.
Source=System.Reactive
StackTrace:
at System.Reactive.Subjects.Subject`1.ThrowDisposed() in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Subjects\Subject.cs:line 64
at System.Reactive.SynchronizedObserver`1.OnNextCore(T value) in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Internal\SynchronizedObserver.cs:line 22
at System.Reactive.ObserverBase`1.OnNext(T value) in D:\a\1\s\Rx.NET\Source\src\System.Reactive\ObserverBase.cs:line 36
at ReactiveUI.ReactiveCommand`2.<Execute>b__18_3() in d:\a\1\s\src\ReactiveUI\ReactiveCommand\ReactiveCommand.cs:line 716
at System.Reactive.Linq.ObservableImpl.Finally`1._.Run(IObservable`1 source) in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Linq\Observable\Finally.cs:line 52
at System.Reactive.Producer`2.SubscribeRaw(IObserver`1 observer, Boolean enableSafeguard) in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Internal\Producer.cs:line 128
at System.Reactive.Linq.ObservableImpl.AsObservable`1.Run(_ sink) in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Linq\Observable\AsObservable.cs:line 20
at System.Reactive.Subjects.ConnectableObservable`2.Connect() in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Subjects\ConnectableObservable.cs:line 44
at System.Reactive.Linq.ObservableImpl.RefCount`1.Eager._.Run() in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Linq\Observable\RefCount.cs:line 85
at System.Reactive.Concurrency.ObserveOn`1.Scheduler.Run(ObserveOnObserverNew`1 sink) in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Concurrency\Synchronization.ObserveOn.cs:line 28
at System.Reactive.TailRecursiveSink`1.Drain() in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Internal\TailRecursiveSink.cs:line 126
at System.Reactive.TailRecursiveSink`1.Run(IEnumerable`1 sources) in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Internal\TailRecursiveSink.cs:line 33
at System.Reactive.Concurrency.Scheduler.<>c_75`1.<ScheduleAction>b_75_0(IScheduler _, ValueTuple`2 tuple) in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Concurrency\Scheduler.Simple.cs:line 65
at System.Reactive.Concurrency.CurrentThreadScheduler.Schedule[TState](TState state, TimeSpan dueTime, Func`3 action) in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Concurrency\CurrentThreadScheduler.cs:line 107
at System.Reactive.Concurrency.LocalScheduler.Schedule[TState](TState state, Func`3 action) in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Concurrency\LocalScheduler.cs:line 32
at System.Reactive.Concurrency.Scheduler.ScheduleAction[TState](IScheduler scheduler, TState state, Action`1 action) in D:\a\1\s\Rx.NET\Source\src\System.Reactive\Concurrency\Scheduler.Simple.cs:line 61
at ReactiveUI.ReactiveCommandBase`2.ICommandExecute(Object parameter) in d:\a\1\s\src\ReactiveUI\ReactiveCommand\ReactiveCommandBase.cs:line 230
at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at SourceTree.App.Main()
This exception was originally thrown at this call stack:
[External Code]
I have tested this on version 3.3.9 to 3.4.2
