SourceTree - how hide staged/unstaged view
tarling June 18, 2015
One of my repos has the working copy split into staged and unstaged files as per the screenshot - the other's don't. I can't find a setting to not use the staged/unstaged view. Does anyone know how to stop it, please?
7 votes
sreekumar_menon
June 19, 2015
Check if it is set to split view staging?
tarling June 22, 2015
Thank you - I missed that option completely.
Chris Ellepola
November 13, 2020
sree.png can't be viewed anymore it seems - see Robin_Gare Answer.
5 votes
Robin Gabre
April 30, 2018
If the image from the other answer cannot be loaded:
In the when showing the 'File Status' window there are 2 drop-down menus just over where the changed files show up.
The first one is for sorting options, and the second one if for how to display the files.
The second menu looks like a hamburger-menu and where you can select:
'no-staging'
'fluid-staging'
'split-view-staging'
mehrantm
May 27, 2018
It shows the staging panel when I choose it however the familiar button to stage files is missing
