On one of my machines, I have somehow hidden the panel which shows commit information, such as the commit hash and the full commit message. Here is the appearance with the commit panel, below the list of files:Screen Shot 2015-04-27 at 9.17.15 AM.png
And here is the appearance without the commit panel:
I'm sure it's just a setting somewhere to bring the commit panel back, but I can't find it. Can anyone help me out?
This single command will only show the commit panel, and not delete any other SourceTree settings. Restart SourceTree after running the command.
defaults delete com.torusknot.SourceTreeNotMAS "NSSplitView Subview Frames repowindow_LogViewDescSplitter"
Thank You! I fixed this issue by replicating what this command does. I edited the plist file "~/Library/Preferences/com.torusknot.SourceTreeNotMAS.plist" manually and deleted the entry for "repowindow_LogViewDescSplitter".
On the Mac, I went to the Finder, opened the "Go" menu and selected "Go to Folder...". I pasted in the path to the file and it navigated right to the file. I double clicked on the file and it opened in Xcode where I could delete the entry.
I only deleted
NSSplitView Subview Frames mergesheet_LogViewLowerSplitter
and this fixed it for me.
Running this command in the terminal worked for me also. Thank you Fabian!
Great solution ! Thanks.
Yes. This works on a Mac.
Beware that this will reset ALL your preferences and you will need to re-login to your Atlassian account. It took me a while to get things back the way I like including Toolbar, Diff tool configuration, and many miscellaneous Preferences.
I can also confirm this works on Mac v2.3.1. You just log back in to your Atlassian account and all your repos are already back ready to go.
+1 it works, however all custom settings got reset (toolbar layout, for instance)
If you want to save your settings, are familiar with the OS X plist format, and are willing to get your hands a little dirty, use a text editor on ~/Library/Preferences/com.torusknot.SourceTreeNotMAS.plist and delete all the key pairs whose key starts with "NSSplitView Subview Frames". There are around 25 of them all in a row. They look like this:
<key>NSSplitView Subview Frames SearchViewDescSplitter</key>
<array>
<string>0.000000, 0.000000, 1101.000000, 309.000000, NO, NO</string>
<string>0.000000, 310.000000, 1101.000000, 423.000000, NO, NO</string>
</array>
@Chris Nordberg's little app works! thx a lot!
I can also confirm that editing the plist as described above brings the panel back.
Of course, one can dream of a world where someone that works on the project would spot this and actually fix it...
👍🏿 @Chris Nordberg's app
In extension to JM's solution, plist file can be open in Xcode and deleting just "NSSPlitView Subview Frames repowindow_LogViewDescSplitter
" fixes the issue.
@Sangharsh Boudhh's clarification above is excellent.
" fixes the issue
This single command will only show the commit panel, and not delete any other SourceTree settings:
Thanks, @Fabian Ehrentraud
I was in the same situation recently, maybe just after update java runtime.
Just now, I've tried Fabian's workaround and it was effective for me, thanks again!
Based on JM's comment I wrote a little tool to reset SourceTree's UI. It's here if you want to download it:
https://drive.google.com/file/d/0BzWLwd_TES6XRno2cW82TVNvNTA/view?usp=sharing
No need for a tool, just run this command:
It will not reset any other SourceTree settings, just restore the commit panel.
I'm also getting this now.. anyone know how to show the commit info panel?!?! Soon as this occurred those two little loader animations (sort of cut off below) started displaying like that...
EDIT: Just got it back!! Started frantically clicking/dragging out to the right, from that top loader animation (sort of cut off in the screenshot) and viola the commit info panel came back. Oddly enough, now commit author photos no longer display.. the question mark icon displays where the author photo used to display. (shrug)
Just in case you edit the plist in some text editor and SourceTree kicks you to login. The plist file is in binary form and saving after editing (like in TextMate) will actually corrupt the plist format in many text editors.
The plist file should be edited in a plist editor, like Xcode.
This has been dup'ed to https://jira.atlassian.com/browse/SRCTREE-4055 which is in the 2.5 release. I currently have 2.4.1 on my Mac, and https://www.sourcetreeapp.com is offering 2.4.1a at the tie of writing.
I managed to restore this by going to Preferences, changing Window Restoration to "Use Mac OS for Window restoration", then restarting SourceTree. HTH!
This repeatedly happens to me, and there is a less-invasive fix (at least on the Mac version) than nuking the settings.
Put the mouse at the left edge of where the commit info panel should be. It's tricky because the sidebar resize splitter is in that spot too, so you will see a left-right-drag-cursor (like <-|->). But slowly move the mouse there and you will see a right-only drag cursor ( |-> ). That cursor will let you drag to resize the panel back into visibility.
It's hard to do because it is a difference of 1 pixel. Also this may not work on small monitors .
Sadly this bug is still present in 2.4.
Another alternative is to open the prefs file (in Xcode or any plist editor) and delete every row that starts with "NSSplitView...". (This can work if the panel comes back, but the internals of the panel are still fubar.)
image2016-12-8 10:37:9.png
I'm using v2.3.1 (69) on a Mac and have the same problem, can't find a way to fix it. I tried re-installing SourceTree, it didn't help.
See if there is an area at the bottom of the file list pane that you can drag upward.
Some other panels in SourceTree have had problems in the past with being able to be resized to zero width/height, and users have trouble finding how to re-expend, but it's typically just a matter of finding the right drag anchor along the edge of where the panel should be.
Full disclosure, I use SourceTree on Windows, which places the commit panel ABOVE the file list, and does NOT allow it to be collapsed to zero height.
Huh, I don't even know what that is. Can you pull up from the bottom of THAT panel? Might as well try pulling down from the top as well.
There should really be an option under View to just change all the panels back to defaults. Which version of SourceTree are you using? On 2.0.5.2 I don't seem to be able to make the commit window go away completely.
Is there any chance you're viewing "Uncommitted changes" in the graph? That panel is hidden when viewing that node, since there isn't a commit to display information about
I'm on 2.0.5.2, and unfortunately, I'm definitely not viewing "Uncommitted changes" - it's a previous commit. Sorry for the delay in replying; as a new forum member I'm apparently prohibited from posting/commenting more than 3 times in 24 hours.
I'm afraid I don't remember my solution, whether it was something clever or just deleting and reinstalling SourceTree. It might have been the latter. (Which isn't actually as big a pain as it sounds, since it doesn't trash your repos themselves - you just have to re-add them to SourceTree.) Good luck!
Thanks, I ended up restoring Source Tree to its factory settings. It seems to be a common problem in the community. Someone should fix or document this.
