SourceTree won't open after minimise
sodally
Since updating to 3.0.5, whenever I minimise the SourceTree window I cannot open it again and I get the angry Windows DING noise. I have to right click it in the task bar, close it, then reopen and it's fine. Anybody else seeing this behavior? I'm using it on Windows 7.
5 votes
minnsey
November 19, 2018
Sourcetree for Windows 3.0.9 which contains a fix is being rolled out.
You can download it directly from http://product-downloads.atlassian.com/software/sourcetree/windows/ga/SourceTreeSetup-3.0.9.exe
Chris Houston November 19, 2018
Hi Michael,
You might know this already, however, when I click "check for update" the dialog shown in the screen shot below pops up.
Cheers, Chris
Like • Carlos Saldarriaga likes this
But the good news is that downloading the installation file you linked to and installing it has fixed this issue, thank you!!
sodally
Works for me! :)
Dominique Heinelt
just got the update notification and updated to 3.0.9, but unfortunately the problem still persists for me.
Justin Nichols November 20, 2018
I now have 3.0.9 and it's fixed for me...mostly.  When clicking the minimize button in the upper right (app is maximized), and then clicking the icon on the taskbar, it activates the icon, but doesn't show the window unless I click a second time.  It is only an annoyance at this point, so thank you for fixing the biggest part of the issue.
Okay, I noticed that it seems to only occur in the way I described above when minimization means that only the desktop is showing (no other windows).  When other windows are behind the SourceTree window, then minimizing the SourceTree window properly re-activates upon clicking the icon.  Or it occurs if minimizing SourceTree using the minimize button and then minimizing all other windows such that only the desktop shows.  It has something to do with having no other windows on the desktop.
SAURABH GUPTA
December 5, 2018
Thanks, This Solution worked for me.
Heidi Bickner December 4, 2019
Thanks, it worked.
7 votes
Turhan Fuad
October 15, 2018 edited
This issue is also occurring for me on windows 10
I have a minor work around for this.
Left click on sourcetree in the taskbar and then press enter.
Also avoid using minimise arrow/keyboard shortcuts just click on the icon in the tray to minimise/maximise which seems to work fine for me, for now.
Deleted user October 17, 2018
Good workaround. I'm also using Windows 10 and have the same issue.
After minimizing SourceTree with the _ icon in the upper right I receive a ding when trying to click on it in the taskbar .
Clicking it and then using Windows+Up or Windows+Down will bring it back, or the method you described: Windows+Enter.
Stéphanie F
October 24, 2018
Thank you for the workaround, works fine!
Like • Edgar Silchenko likes this
Viigoo
October 25, 2018
double left mouse click also works for me
Turhan Fuad
Also worth keeping in mind pressing Enter will actually send the enter key to the program.
A better solution would be to click on the icon then press [windows logo key] + [up]
Edgar Silchenko
September 6, 2019
Thanks for workaround!
fordp2002
October 24, 2018
I just upgraded to 3.0.8 and it still has this problem.
Robert Szcześniak
October 24, 2018
I confirm, Still the same problem in version 3.0.8.
mharris08
October 24, 2018
I also confirm. I upgraded to version 3.0.8 on windows 7 pro.  Still the same problem.
Hans Langouche
October 25, 2018
Same problem with latets 3.0.8 update, 2 screens.
Nathanael Padgett
November 1, 2018
Experiencing the same issue on two different systems (Dell deskop & Lenovo Laptop). It is working okay inside Citrix desktop for me though.
Scott August 28, 2019 edited
Windows 10 - 3.0.17 and it still fails.
edit: seems Choco isn’t correctly updating the ST package. Will try again with manual install and see if the problem recurs.
_alexbk66
Why are you on 3.0.17 and complaining?  The latest is 3.1.3
Like • Scott likes this
_alexbk66
This is still an issue in 3.0.17.
1. On a laptop without external monitor it happens only after one click on the taskbar icon, second click (usually) brings SourceTree  window.
2. On a desktop with two monitors it's getting worse - before at least after multiple clicks on the taskbar icon SourceTree  window could appear.  Lately it doesn't work at all.
@"Jacob H" Thank you for a workaround - clicking Windows button + Up button works!
BTW, status of this issue shouldn't be SOLVED - because it's not solved!
minnsey
May 7, 2019
Can you try upgrading to 3.1.2 or above?
lievendf
May 7, 2019
3.1.2 has some nasty bug(s) of disappearing bookmarked repositories when opening a new tab and clicking around. I'm staying away from it for now and downgraded back to 3.0.x...
_alexbk66
May 8, 2019 edited
I didn't realise there's an update. I'll try and report.
[EDIT] Updated, actually twice - 3.1.2 then to 3.1.3.
So far so good.
Marc Wuillemin
March 20, 2019
SourceTree 3.1.2 fixes the problem for me (Windows 7 64bit).
minnsey
March 20, 2019
Thanks for the feedback
lievendf
February 7, 2019
I only have it when working on a remote desktop session using Windows 7
minnsey
February 7, 2019
Hi
Thanks for the extra detail. To be honest that is not a scenario that test consistently.
zemmyindrapatih
December 19, 2018 edited
Using 3.0.12. Still take time to restore the window.
I had to click for a couple times then the window will show up. :(
Getting angry when this happen when i need sourcetree urgent.
minnsey
January 9, 2019
Thanks for the feedback. We do try to test in as many combinations as possible and it does work in our environments but we will continue to investigate.
Simon Goldsmith
December 17, 2018
Fixed for me, using dual monitors and 3.0.12 :D
minnsey
December 6, 2018
tony corner
December 13, 2018
I upgraded to 3.0.12.2543 and it stills seems to be happening
Dominique Heinelt
Same here. This bug still occurs for me (using v3.0.12.2543, Dual monitor, both 1920x1080, on Windows 7 as well as on Windows 10)
minnsey
January 9, 2019
minnsey
November 7, 2018
Hi
A fix for this is just being released to beta testing and should be available to all users soon.
Chris Houston November 12, 2018
Great news, FYI, I also have the same issue on a single monitor setup ( Wide screen 3440 x 1440 ) so am looking forward to this being fixed!
Turhan Fuad
Works for me.
Glenn Spies November 20, 2018
The problem still occurs.
Version 3.0.9, Windows 10 Pro, dual monitors using rdp (remote machine has issue)
Seems to be reproducible by using "Show desktop" -> all minimise, click SourceTree -> it makes a sound -> nothing happens (still minimised, enter works)
Justin Nichols November 6, 2018
Yet another "happens to me".  This happens whether or not there are multiple displays.  It is simply triggered by minimizing using the upper-right minimize button and then attempting to click the icon in the taskbar.  Should be rather simple to reproduce.  I am on Windows 10 build 1803 presently.
Can also confirm the workaround above works.
bankingondan
October 26, 2018
Seeing this on v3.0.8. I have a Lenovo Y50 laptop + external monitor. It happens both on laptop only and laptop + external monitor, so it is not unique to dual monitors. The current workaround I'm using is clicking on the taskbar icon and hitting Enter to bring the screen back up.
David Campbell October 23, 2018
Created a jira for this here: https://jira.atlassian.com/browse/SRCTREEWIN-10755.
Had to downgrade from 3.0.8 back to 2.6.10.0 and the issue when away.
fordp2002
October 12, 2018
I have this and yes "bring to front" from the task manager does work.
Robert Szcześniak
October 9, 2018
I have the same problem. Windows 7 Enterprise 64bit, first monitor 1280 * 1024, second 1680 * 1050. I found a way to run Sourcetree after minimizing the application. This is possible using the task manager.
sodally
This also works for me.
minnsey
October 8, 2018
Hi
Thanks for reporting this. We have seen a handful of similar reports and are investigating though currently we can't reproduce it.
Can you provide any more details that might be relevant? e.g. are you using multiple monitors, especially hi-definition settings etc?
Manuel Guillen
October 8, 2018
I have the same exact issue, except I am running Windows 10. I am using two 1080p monitors.
sodally
I am running dual screens. 1x DisplayPort (2560*1440) and 1x DVI (1920*1080). Graphics card is an NVIDIA Quadro K4000 if it's relevant.
Turhan Fuad
I can only produce it when I minimise the window using logo+down or the minimise button.
If i keep clicking the icon on the taskbar it will minimise/maximise without much issue (sometimes it doesn't minimise/restore so I have to press it again)
Ethan Thornburg
October 22, 2018
I'm also running into this on Windows 10. Two 1080p monitors and a Radeon RX 460
Andreas Skagestad
October 23, 2018 edited
I have the same issue. Windows 10, Lenovo y50-70, Dual monitors (different DPI). I have to close and reopen every time I minimize. I tried the workaround with "Bring to front" in task manager, and it works"
Glenn Spies October 23, 2018
Same issue both locally and over RDP. Dual monitors 2560x1440 same DPI
Workarounds work.
Can I suggest the team try use standard windows controls for the application? Custom might look nice but it causes untold issues with remoting/windowing software.
adenb
October 23, 2018
I can also reproduce the issue when using the "_" minimise button or the Windows Key + down arrow. Minimising by clicking the taskbar icon does not.
Running 2x identical 1080p monitors, Windows 10.
Sometimes after minimising the window with the "_" button, spam-clicking the icon in the taskbar can reopen it. Otherwise, the workarounds of clicking the taskbar icon + enter or Windows Key + up arrow work.
Tom F
October 24, 2018
I have a similar Problem.
To reproduce it:
1. Minimize Sourcetree
2. Put Windows 10 into sleep mode
3. Wake it up again
Then the Sourcetree window can't be restored
Kumpuu
October 29, 2018 edited
I have the same issue. Click the minimize button in the top right corner, maximizing from task bar does not work. The workaround described above works.
I'm running Win10, ST 3.0.8, single 1080p monitor.
